#3181
Posted 23 February 2013 - 10:33 PM
#3182
Posted 23 February 2013 - 10:43 PM
#3183
Posted 24 February 2013 - 08:36 AM
#3184
Posted 24 February 2013 - 09:57 AM
#3185
Posted 24 February 2013 - 10:19 AM
#3186
Posted 24 February 2013 - 10:27 AM
#3187
Posted 24 February 2013 - 10:33 AM
#3188
Posted 24 February 2013 - 11:43 AM
#3189
Posted 24 February 2013 - 12:31 PM
#3190
Posted 24 February 2013 - 03:56 PM
#3191
Posted 24 February 2013 - 09:03 PM
#3192
Posted 25 February 2013 - 11:08 PM
#3193
Posted 25 February 2013 - 11:32 PM
#3194
Posted 26 February 2013 - 10:03 AM
#3195
Posted 26 February 2013 - 11:17 AM
#3196
Posted 26 February 2013 - 12:58 PM
Random thought (might be pish): If you knock up a bias box (which is fairly easy) could you use the two lines from this into the abs block and still get decent bias adjustment? These would just replace the two lines from the OE MC so it might work and give you good adjustment. Alternatively you'd have to bin off the abs and I'm not sure of the implications of doing this.
I think there's a few people who bin their S2 Exige ABS units and replace with dual master cylinders and a bias bar. Only implication is road legality
#3197
Posted 26 February 2013 - 01:02 PM
#3198
Posted 26 February 2013 - 01:14 PM
#3199
Posted 26 February 2013 - 01:57 PM
#3200
Posted 26 February 2013 - 02:26 PM
your over-thinking this....Random thought (might be pish): If you knock up a bias box (which is fairly easy) could you use the two lines from this into the abs block and still get decent bias adjustment? These would just replace the two lines from the OE MC so it might work and give you good adjustment. Alternatively you'd have to bin off the abs and I'm not sure of the implications of doing this.
MC to ABS is only 1 pipe per cct (front/rear), if you want to fit a bias valve, you have to do it BEFORE the ABS unit - otherwise it (the ABS) will not understand what's going on as you have just detached it from the wheel calliper and thus it does not know what pressure the line is at.
In this case, I don't know how well the ABS is going to cope with the change of callipers as well as the change in tyres sizes (from what it was configured for), the std tyres are only 1.6% different, the Kuhmos are some 9% different, so I suspect not well!
