#3341
Posted 06 March 2013 - 11:34 AM
#3342
Posted 06 March 2013 - 01:04 PM
Edited by Chill, 06 March 2013 - 01:06 PM.
#3343
Posted 07 March 2013 - 08:40 AM
Liam at MMG has designed us a new rear diffuser which will be for race only and the prototype is now ready and below are a few pics. It is longer than a standard MMG 5 fin to better deal with the air passing under the car and wider to take in the area of dead air that exists with standard diffusers adjacent to the rear wheels.
#3344
Posted 07 March 2013 - 09:47 AM
Need to get rid of unnecessary wiring
And that poxy alarm if it's not gone already
#3345
Posted 07 March 2013 - 10:07 AM
#3346
Posted 07 March 2013 - 10:43 AM
#3347
Posted 07 March 2013 - 10:49 AM
Fins are that depth due to our lower ride height and reduced ground clearance.
#3348
Posted 07 March 2013 - 10:50 AM
Arnt them fins a little shallow? Cant see very well on my phone tho.
Haha I said that too on fbook forgetting Mikes car is a lot lower now, dont think they can go deeper on Mikes
#3349
Posted 07 March 2013 - 10:51 AM
Beat me to it
#3350
Posted 07 March 2013 - 10:56 AM
#3351
Posted 07 March 2013 - 10:58 AM
#3352
Posted 07 March 2013 - 12:33 PM
Ah thats fair enough then
Have you used 340r top front wishbones now we are running such a low ride height?
No need with the new EP Tuning Hubs.
#3353
Posted 07 March 2013 - 02:26 PM
#3354
Posted 07 March 2013 - 04:14 PM
#3355
Posted 07 March 2013 - 04:17 PM
OK, have to ask....Ah thats fair enough then
what makes you say/think this?
(as in what do you think 340r top wishbones are compared to normal ones?)
Edited by Scuffers, 07 March 2013 - 04:17 PM.
#3356
Posted 07 March 2013 - 05:40 PM
given that IIRC you're at a rear ride hight of 60mm then they should extend to the min ground clearance allowable in the regs of 40mm to cut as much leakage between channels as much as possible, they also really need to extend as far forward as possible. I've no idea WTF that in the middle is supposed to be, it won't act as a double diffser or add any negative pressure that's for sure. Sorry to be netgative but from the looks of it the majority extra downforce from this will be due to weight.
To answer jamies question the ramp anlgle should be dependent on the ride hight in that for a standard ride hight you can keep a ramp of 12 or more degrees and the flow won't seperate away however if you drop that to 50-60mm then you need a much lower angle like the classic 7 degrees to keep the flow attached.
#3357
Posted 07 March 2013 - 06:27 PM
The disparity left to right over the rear axle is due to the engine sitting to the right and the gearbox (much lighter) to the left.
Didn't weight it last season sadly but I reckon we were probably about 30-40KG heavier.
Weight is without driver or fuel.
Sorry if this is a stupid question as I don't really know a lot about this stuff, but when you use corner wieghting to set up the geo of the car should you have driver on board to set it up properly?
#3358
Posted 07 March 2013 - 06:39 PM
depends on what your trying to do...Sorry if this is a stupid question as I don't really know a lot about this stuff, but when you use corner wieghting to set up the geo of the car should you have driver on board to set it up properly?
in this case, I just put it on the scales to see what the total was, I was not doing a geo or the like, I was just getting a base-line of what I am dealing with (so that I can then decide on spring rates, heights, etc)
Now, Obviously I set the spring platforms beforehand, at what I guessed would be about right (in terms of ride hight etc), and then plonked it on the scales, that picture is what I was greeted by.
this says two things to me:
1) the car is somewhat lighter than I expected (always assumed the VX weighed a lot more than this - although the Turbo probably does)
2) spending hours corner-weighting is pointless, just set the pre-load right in the first place and the corner weights will be right.
Yes, once Mike get's in it, they will change, but so what? you cannot change that without physically moving weight about, and once the car is on a track and moving, the wheels are never going to be level anyway, all that's important is that the balance remains even (front/back/side/side).
#3359
Posted 07 March 2013 - 07:23 PM
OK, have to ask....
because mr scuffers, the 340R front top wishbones have an angled top ball joint housing.. so as you lower the car and the wishbones point upwards the angle of the housing allows the ball joint to sit vertical and not at an angle like a straight wishbone would do.
#3360
Posted 07 March 2013 - 08:32 PM
