4350 replies to this topic
#3441 techieboy
Posted 18 March 2013 - 11:10 AM
Holy guacamole. :o How does the wing work when you're towing it on a trailer? Poor tow car must be in danger of lift off at the rear axle at motorway speeds. :lol: Bit of a p!sser on the SC belt front but guess that pulley must need further alignment (however that's done). Did you try running the belt on the inner 5 peaks and another belt on the outer 5, to see if that helped?
#3442 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 18 March 2013 - 11:17 AM
Holy guacamole. :o
We checked the alignment and all seemed OK, I just think it was too long.
No pics from the front though.
#3443 Exmantaa
Cadwell yesterday was a bit mixed. When the car ran, it was sweet and handling is epic. Sadly we shredded a few drive belts and had to take an early bath.
Do you have a 6 rib or still on the 5pk belts??
Me think you need to upgrade a.s.a.p... :glare:
We still on 5pk. If I can go to 6 rib cheaply and easily I would. No idea what I need, where to find it and how much.
You need an LSJ 6 rib crank pulley. (If you are in a hurry I have one here that I don't need right now.)
And an alternator 6 rib pulley. Vocky made some adapters and I probably can make something suitable too with a slightly bigger Alt. pulley (better for higher revs.)
#3444 Scuffers
Scuffers
  • 1,306 posts
Posted 18 March 2013 - 11:26 AM
That would be the sensible option
#3445 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Thanks Exmantaa. It is a conversion I want to do so any help is appreciated.
#3446 The Batman
Posted 18 March 2013 - 11:57 AM
I have a 6 rib crank pulley in the shed of love. Then get Vocky to modify the alternator pulley You need a 6 Rib sj one from American eBay
#3447 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 18 March 2013 - 12:14 PM
Cheers Joe, can you find me the alternator pulley?
What will the crank pulley cost me?
#3448 techieboy
Posted 18 March 2013 - 12:28 PM
Just been out to check my B207 engine as you could have had the crank pulley from that but, it's a 5 peak as well. :(
#3449 Exmantaa
Posted 18 March 2013 - 12:32 PM
Yep, 6 rib is an US-LSJ exclusive item. :happy: So Joe is delivering the parts then?
#3450 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 18 March 2013 - 12:34 PM
Muncher might have a 6 rib crank pulley
#3451 The Batman
Posted 18 March 2013 - 12:37 PM
I have a lsj alternator I maybe able to take the pulley from but need to check. I'm out picking up the pedal car at the moment will check later
#3452 techieboy
Posted 18 March 2013 - 12:49 PM
Is there any practical benefit to moving to 6-rib (bearing in mind other than on the second day after the original conversion, I've never needed to replace a belt), as I guess that means going through the pain of moving the pulley on the SC back to it's "standard" position?
#3453 Scuffers
Scuffers
  • 1,306 posts
Posted 18 March 2013 - 01:19 PM
don't know the detail of the loads on the TVS in your install, but I was somewhat surprised at the use of a 5 rib belt... we use 7 rib ones on SC Honda's and they have proven hard enough to get strong enough belts, I am amazed a 5 rib will cut it... (consider that a SC can easily be pulling 50+ hp from the crank).
#3454 techieboy
Posted 18 March 2013 - 01:23 PM
7 rib? Damn, that's some hefty belt. I'm not TVS'd, I'm still on the old M62 with an undersized 2.9" pulley but guess there's probably not a huge amount in it loadwise. Hmmm, maybe the initial pain of messing with the pulley again is worth it..... :wacko:
#3455 chris_uk
Posted 18 March 2013 - 01:30 PM
We ran the 5 rib all last year without a hint of a problem. Then we bust 2 belts in as many laps. I dont consider the no. of ribs to be an issue atm. However if we can change it all to incorporate a 6 rib cheaply then im all for it.
#3456 Exmantaa
Posted 18 March 2013 - 01:41 PM
LSJ alternator is a one-direction freewheel pulley. You need some special tools to disassemble it from the Alt. and it then needs to be welded solid for the other rotation...
Easier to simply mod a solid 6rib pulley.
#3457 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 19 March 2013 - 10:18 AM
This is a more flattering angle.
#3458 Goosenka
Goosenka
    Jeep Driving jolly nice chap
  • 12,716 posts
Posted 19 March 2013 - 10:19 AM
:thumbsup:
#3459 techieboy
Posted 19 March 2013 - 10:23 AM
Are you not doing anything about the transition from front clam to splitter, this year, Mike?
#3460 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 19 March 2013 - 10:38 AM
On the list for this weekend Matt.
