#3541
Posted 18 April 2013 - 10:22 AM
#3542
Posted 18 April 2013 - 10:25 AM
#3543
Posted 18 April 2013 - 10:32 AM
#3544
Posted 18 April 2013 - 10:55 AM
G-Bob wins the car sticker.
348 BHP and 301 lbft
Very happy with the hike in torque, I only wish the BHP could have matched it. The only thing we can pinpoint as a possible restriction is the exhaust system otherwise we should have matched the Harrop'd 370 they have seen before.
A nice step in the right direction
How much are your inlet valves lifting Mike and what's their open duration? Also what's the I/D of your exhaust primaries and the rest of the exhaust as a matter of interest?
#3545
Posted 18 April 2013 - 10:56 AM
Aslong as there are no probs with the injectors etc and the engine is safe and healthy, id be quite happy with that outcome.
Nearly an extra 40ft/lb will deffinatly not go un-noticed.
I am happy with it to be honest Chris and it is plenty fast enough for me, it is just that others have made more and you can't help wanting the same power level as them.
#3546
Posted 18 April 2013 - 11:03 AM
#3547
Posted 18 April 2013 - 11:14 AM
And the results are in; anybody fancy a sweepstake?
The before figures were 333 BHP and 264 Lbft.
Two changes were 2.9 pulley to 2.75 and the addition of the Bosch 044 pump.
Did they look to the boost pressure and intake temps with that small pulley?? Ultimate had very high IAT temps with his 75mm (2.95) pulley and my mate with a 80mm Harrop already tips the 50*C with spirited road driving. (1.45bar boost though due to a restrictive exhaust.) Both on 2.0 engines though.
Hope the engine is still within safe limits for race use...
#3548
Posted 18 April 2013 - 12:31 PM
Sooooooo close!
The torque in the midrange will help you inbetween the corners when not at full revs, so it all helps.
#3549
Posted 18 April 2013 - 01:00 PM
It is mapped on the safe side.
IETs will always be the enemy but I can take cool down laps in Time Attack so not all is lost.
Edited by Cliffie, 18 April 2013 - 01:19 PM.
#3550
Posted 18 April 2013 - 07:26 PM
that is a nice result348 BHP and 301 lbft
I have to agree that the exhaust manifold is perhaps a little too small for a Harrop
But at least you are well below the limit of the liners
#3551
Posted 18 April 2013 - 07:31 PM
No idea Nev, Cocky timed the cams and may know. They are blower cams.
Primaries are 1.75 I believe.
#3552
Posted 18 April 2013 - 07:56 PM
#3553
Posted 18 April 2013 - 08:11 PM
3" system with 1.75 primaries.Which size of exhaust do you run?
Regards, Per
#3554
Posted 18 April 2013 - 09:02 PM
1.75" primaries are quite large IMO (assuming that's the I/D), I don't think your restriction will be from that. Nippers are considerably smaller than that for instance. The 3" pipework might be a mild restriction at a guess. I did some calcs on nipper using gas laws to calculate the thermal expansion of gasses and thence the flow speeds to be expected in a 3" pipe. You could do the same - the results will scare you most likely! LOL
As a matter of interest, at what power level and torque level would you consider "enough" for the kind of tracks you are on? ie at what point is any more power useless (assuming a dry and warm day and semi-sticky tyres).
Edited by Nev, 18 April 2013 - 09:06 PM.
#3555
Posted 18 April 2013 - 09:07 PM
#3556
Posted 18 April 2013 - 09:28 PM
I think tracks have a way of always leaving you wanting for more power. Cars can feel very fast on road but as soon as you come out of a corner onto the back straight I can never have enough power I think
Sounds like it could be Garrett time
#3557
Posted 18 April 2013 - 09:29 PM
Edited by jameso, 18 April 2013 - 09:30 PM.
#3558
Posted 18 April 2013 - 09:39 PM
#3559
Posted 19 April 2013 - 07:23 AM
Regards, Per
with a 2.75 pulley I would have said 380+ bhp
Both on a 3"system, think my primaries are the same size also, your comp blower cams aren't you? one thing which may be different is Jim put a really BIG cat on mine, unless there is a difference in back box?
Edited by NickB777, 19 April 2013 - 07:27 AM.
#3560
Posted 19 April 2013 - 07:35 AM
