4350 replies to this topic
#3581 Winstar
Winstar
  • 4,264 posts
Posted 22 April 2013 - 02:21 PM
Managed to grab an hour on the car over the weekend and started plumbing the NOS in.
are you sure that's wise? I'd be calculating what the parasitic loss of the charger is first as although the dyno only reads 348 bhp the power that the internals sees will also include the power needed to drive the charger so quite a bit higher.
#3582 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 22 April 2013 - 02:34 PM
Liners are rated at 400bhp by GM I have read, whats the drain on the engine running the s/c 25bhp? 375bhp tops?
The findings, from the original Bothwell "test to destruction" series of test's (which the GM manual reference) were conducted using nos and/or turbo but not s/c
Edited by NickB777, 22 April 2013 - 02:37 PM.
#3583 FLD
Posted 22 April 2013 - 02:50 PM
NOS is a bearing and rod killer. Be prepared to rebuild bottom ends and replace rods fairly frequently if you go for anything other than a tickle sized shot.
#3584 Winstar
Winstar
  • 4,264 posts
Posted 22 April 2013 - 03:00 PM
just done a rough calc off the TVS1320 map on line and I get 20.6 kW (27.5 bhp) to compress the air so i'd say at least 30bhp with mechanical losses
#3585 vocky
Posted 22 April 2013 - 05:22 PM
If the exhaust is restricting power then the NOS possibly won't make any difference to the max bhp, just add some mid - high range grunt :unsure:
#3586 Nev
Posted 23 April 2013 - 08:59 PM
How much boost is he running to get 355 BHP? I'd be interested to compare his VE to Nippers, just for background knowledge. Is his swept volume still 2200 cc ? And also what the SCR please?
Edited by Nev, 23 April 2013 - 09:02 PM.
#3587 chris_uk
Posted 23 April 2013 - 09:10 PM
probably 1.25bar. 2300cc i think with the re-bore and im assuming SCR is selective cat reduction.?
#3588 NickB787
NickB787
  • 7,813 posts
Posted 23 April 2013 - 09:11 PM
These were from an the Cobaltss site, 8.9:1 low comp pistons, Mike is running a 2.75"
64mm / 2.5" ~ 27.5 psi
70mm / 2.75" ~ 25 psi
75mm / 2.95" ~ 22.5 psi
80mm / 3.15" ~ 20 psi
85mm / 3.35" ~ 17.5 psi
89mm / 3.5" ~15psi
#3589 The Batman
Posted 23 April 2013 - 09:16 PM
2256cc or so
Edited by The Batman, 23 April 2013 - 09:16 PM.
#3590 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 24 April 2013 - 07:56 AM
I didn't even know I had an SCR.
#3591 LY_Scott
LY_Scott
    Formerly LY055SCO
  • 9,221 posts
Posted 24 April 2013 - 07:59 AM
Its next to the foofoo valve under the snarflaps.
#3592 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 24 April 2013 - 08:00 AM
Static Compression Ratio
#3593 CocoPops
CocoPops
  • 17,182 posts
Posted 24 April 2013 - 08:02 AM
If you can't dazzle them with brilliance, baffle them with bullshit :rolleyes:
#3594 FLD
Posted 24 April 2013 - 11:47 AM
NOS adds low down grunt. Its gas from a nozzle so diffuses out at a set rate. At low revs you'd therefore get more in each cylinder as more gas has come out of the nozzle. Same flow rate for high revs so less into each cylinder.
#3595 Nev
Posted 24 April 2013 - 11:49 AM
Explain to me why knowing a fundamental thing like SCR (particularily on a boosted engine) is bullshit please?
As usual, you are quick to judge (negatively and condescendingly as usual) when someone asks a perfectly sensible thing. People like you spoil this site which your constant digging.
Edited by Nev, 24 April 2013 - 11:50 AM.
#3596 siztenboots
Posted 24 April 2013 - 12:46 PM
Asking what the piston SCR is seemed a perfectly reasonable question. I am guessing Mike has the Wiseco and Eagle rods, like this maybe 87mm overbore though , http://www.ebay.com/...t-/270771648161
#3597 The Batman
Posted 24 April 2013 - 12:53 PM
http://www.allecotec...products_id=112
#3598 siztenboots
Posted 24 April 2013 - 12:56 PM
0.020" , which is 0.5mm , so 86.5mm
#3599 slindborg
Posted 24 April 2013 - 02:28 PM
Nev, what maths will you be using for the VE? I have a calculation for VE while running but needs sensor values to calculate properly
#3600 techieboy
Posted 24 April 2013 - 02:36 PM
What is VE? Volumetric Efficiency? What does that mean? Do I want some/need some and how much of it?
