4350 replies to this topic
#4001 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 10 June 2013 - 08:15 PM
Ha ha, Mike that's classic!!!  Up to your old tricks :D
#4002 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 10 June 2013 - 08:30 PM
Needed to avoid another car that had spun so took to the green stuff to help mow the meadow.
#4003 chris_uk
Posted 10 June 2013 - 09:09 PM
i thought it was quite a cool day at snett..
charlie on the other hand ...
#4004 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 10 June 2013 - 09:17 PM
5 men 4 men 3 men 2 men 1 man and his dog....  :)
#4005 CocoPops
CocoPops
  • 17,182 posts
Posted 10 June 2013 - 09:18 PM
They've got another engine according to the thread on s2ki... Chq book racing at its finest :lol: Dry stumped this time round as they think it was oil surge.
#4006 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 10 June 2013 - 09:38 PM
What happened to the guy that was sponsoring you a full stand alone ecu last time I was at matts?
Time was not on our side Joe, we needed it running.
#4007 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 10 June 2013 - 09:43 PM
Not guilty for once. Banging round Corum at just over 100 I hit some oil, no worries as I held the slide and was quite happy until there was a Norris Evo sideways across the trank and another on the grass on its way back on circuit. I thought the grass was the best option even though it did rip one of the splitter supports through the clam.
#4008 smiley
Posted 10 June 2013 - 09:50 PM
Very clean and small rip.
I would have expected quite a big backplate behind the clam to handle the force.
#4009 chris_uk
Posted 10 June 2013 - 10:01 PM
then it would just rip a bigger hole out of the clam.
#4010 smiley
Posted 10 June 2013 - 10:17 PM
Ah, like our oem trackrods; designed to snap under stress.
Edited by smiley, 10 June 2013 - 10:17 PM.
#4011 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 11 June 2013 - 05:58 AM
#4012 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 11 June 2013 - 06:46 AM
:yeahthat:  Probably not have ripped a hole at all with sufficient support.
Did the dive planes make any noticible difference?
#4013 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 11 June 2013 - 08:18 AM
The front felt more planted on the higher speed corners and less prone to understeer; on the hairpin, nowt.
#4014 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 11 June 2013 - 08:19 AM
TMAP you need anyway.
(you run a smaller SC pulley now than last year? So more boost.)
FYI, I just asked Peter if maybe something is possible for you...  :happy:
Cheers Exmantaa,
I take it the T in TMAP  stands for temps as it monitors intake temps and therefore has another wire?
#4015 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 11 June 2013 - 08:30 AM
yes  you take one of the wires from the sensor in the intake pipe, so you only them measure the manifold temps
#4016 techieboy
Posted 11 June 2013 - 08:39 AM
But you shouldn't use the T in the TMAP sensor without a remap, as it'll be measuring inlet temps post-SC rather than your current map which will be setup for inlet temps measured pre-SC. Obviously, with the car suitably mapped (or running the Dutch firmware), it would be much better to be using the full TMAP functionality with the inlet temps measured post-SC in the inlet manifold.
#4017 siztenboots
Posted 11 June 2013 - 08:48 AM
The fueling/ignition maps should not be compensating for the true value of T after the laminova's have changed the air charge , that function is already handled perfectly well in another map table. So imho fit the TMAP with the existing map, it just might fix the over fuelling problems.
#4018 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 11 June 2013 - 08:51 AM
So why not fit the TMAP and not use the T function, leave the T pre charger and have the benefit of the higher spec boost sensor?
#4019 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 11 June 2013 - 08:53 AM
Or... Go back down to the 2.9 pulley, my old map (which didn't cause these issues) and just switch on the gas when needed?
#4020 smiley
Posted 11 June 2013 - 09:01 AM
All i know is that you were very happy with the car last year.
With this years extra skills hardware and earo that combo should do just fine.
Only fiddle with the hardware that´s map related, when you have the dutch stuff. (either soon or next year whatever)
Would hate to see this experimenting destroy the season.
