#4141
Posted 11 September 2013 - 07:28 AM
#4142
Posted 11 September 2013 - 07:38 AM
Some kind of OBD reader to scan the IAT value, but think OpCom can log the parameters and store in a csv file.
#4143
Posted 11 September 2013 - 07:44 AM
#4144
Posted 11 September 2013 - 09:02 AM
Real time it can off course, but not sure on logging capability of the Scangauge II. A bluetooth OBD reader and some Smartphone app are probably more capable...
#4145
Posted 11 September 2013 - 09:11 AM
anything that will raise temperatures in the cylinder will help promote detonation
so ;
very lean air/fuel ratios
poor charge cooling
compression of the air molecules from forced induction
poor heat dissipation through the cooling system ( coolant , oil , exhaust )
#4146
Posted 11 September 2013 - 09:16 AM
#4147
Posted 11 September 2013 - 09:21 AM
#4148
#4149
Posted 11 September 2013 - 09:38 AM
set the SG to display the same data on all four buttons , this will reduce the amount of comms , plus 4x update speed. In the background the SG is also requesting lots of other variables which the ECU has to switch modes to access.
#4150
You don't need to datalog everytime. Once you see the IAT reaching 80+*C during a spirited practice session, you know you have some serious cooling issues...
#4151
Posted 11 September 2013 - 09:43 AM
once Mike knows the best cool down lap strategy , this mean keeping speed up through the rads and might need 2 laps , waiting for temps to drop to nominal , even running the heater helps
#4152
Posted 11 September 2013 - 10:28 AM
Some measurements from our German colleagues:
Letzthin auf der Rennstrecke hatte ich nach 3-4 Runden folgende Werte gemessen (Harrop + 75mm/2.95" pulley): Rücklauftemperatur des Wassers (Ausgang Laminovas ) 60 Grad und 95 Grad Lufttemperatur!!! Trotz Thermal-Gasket und Dual Pass Endplatte. Ich persönlich vermute eher, dass die Laminovas total überfordert sind (unterdimensioniert).
So he reaches that after 3 to 4 laps on the track...
(My mate's harrop has a 80mm/3.15" pulley fitted and came to 89*C. He is now testing with water injection...)
#4153
Posted 11 September 2013 - 11:07 AM
I think there is no escaping from water injection, as long as the laminova design is as it is right now.
#4154
Posted 11 September 2013 - 11:10 AM
Working on that last part... (very slowly)
#4155
Posted 11 September 2013 - 11:20 AM
You keeping an eye on Thomasses longcore design, or you have plans of your own?
#4156
Posted 11 September 2013 - 11:25 AM
can you refit SC so the pulley is where the power steering pulley would be, and gain more space to package a chargecooler between the SC and manifold
#4157
Posted 11 September 2013 - 12:25 PM
I gave him the adress where he bought that longcore...
Refitting the SC lower would be optimal, but very tricky for packaging (oil filter housing) and lots of custom fabrication. It's talked about here before, but easiest option is to relocate the (smaller) alternator to a lower (AC pump) position and use the gained space for longer manifold cores....
Or somehow cramp a 5th/6th core into the short mani design...
Simple to think it out, but fabrication of such manifold it is something else. Not much faundry's here in NL to help me out...
Edited by Exmantaa, 11 September 2013 - 12:28 PM.
#4158
Posted 11 September 2013 - 12:30 PM
#4159
Posted 11 September 2013 - 12:38 PM
Resistance...
But maybe it works good enough.
Edited by Exmantaa, 11 September 2013 - 12:39 PM.
#4160
Posted 11 September 2013 - 12:45 PM
8 user(s) are reading this topic
0 members, 8 guests, 0 anonymous users
