#941
Posted 27 April 2012 - 10:50 AM
#942
Thats about right, the pistons won't add any power.
If you've fitted lower compression pistons, they actually drop the power.
#943
Posted 27 April 2012 - 11:02 AM
Not at all. The lower comp pistons allow higher boost which will in turn give higher power. My issue isn't pistons, it is my cams that are letting me down restricting intake duration at the top end.
#944
Posted 27 April 2012 - 11:06 AM
#945
Posted 27 April 2012 - 11:08 AM
Instantly dropped the power of my original high compression conversion 12bhp moving to low compression pistons despite being remapped with them. What it did mean was being able to run more ignition advance and gave a bigger safety margin. Power only increased again with smaller pulley, different injectors and new stoopid exhaust.
Which is the full stage three conversion Techie. You are on a 2.9 I assume?
#946
Posted 27 April 2012 - 11:16 AM
#947
Posted 27 April 2012 - 11:22 AM
#948
Posted 27 April 2012 - 11:26 AM
if there weren't other silly bhp in the class, then just stage 2 would have been sweet.
Agreed Steve and Jimmy won class last year with 263BHP so proof that it is just about right. Sadly everyone has chased power and as much as I can get the thing round corners and brake late and get the power on early, there are a good few long straights where lack of puff will be the points breaker such as Snetterton, Cadwell and Anglesey.
#949
Posted 27 April 2012 - 11:48 AM
#950
Posted 27 April 2012 - 12:29 PM
Low CR & Eaton Supercharger is not a very good combination as Techie experienced... Better keep the CR around 9.5 and the SC boost not too high. (Avoid SC power loss + high temps.)
And if you fitted hotter cams that keep the inlet valves longer open (lowers dynamic CR) it may be wise to go 10.0 CR.
But you do need a good mappable ecu to tweak the ignition tables...
#951
Posted 27 April 2012 - 05:47 PM
#952
Posted 27 April 2012 - 05:51 PM
#953
Posted 27 April 2012 - 06:36 PM
with some simple calcs
If one lowers CR from 10:1 down to 8.9:1
to negate this the pulley is reduced to 3.0 that returns you to status quo
So 2.9 pulley is only a 3% increase (almost linear growth)
I agree with Exmantaa Infact I think with reduced dynamic CR due to Cams, it may be advantageous to Raise CR to over standard 10:1 as we know that standard (10:1) is acceptable
Edited by atom x, 27 April 2012 - 06:40 PM.
#954
Posted 27 April 2012 - 06:38 PM
#955
Posted 27 April 2012 - 06:47 PM
same power being?lee had standard compression and a 3" pulley and got exactly the same power
altering CR should not affect MAP as it does not alter Manifold pressure's
Edited by atom x, 27 April 2012 - 06:51 PM.
#956
Posted 27 April 2012 - 06:49 PM
#957
Posted 27 April 2012 - 07:12 PM
Not complete Status Quo, as the smaller pulleyed SC takes now more power to spin (less crank HP) and the higer boost/revs pushes it into a less efficient zone (higer intake temps).
But it's tricky trade-off... => Use E85 or Meth injection and you can still run ~25* advance on a high-ish compression.
#958
Posted 27 April 2012 - 10:08 PM
I have low compression pistons and 3 pulley inch = 255bhp (required VXR Injectors)
Sutol originally std internals 249bhp, changed to low compression went to CMS an no difference in BHP or map
#959
Posted 27 April 2012 - 10:09 PM
#960
Posted 27 April 2012 - 10:11 PM
your exhaust is hugely restrictive
true, nowt wrong with my Milltek Straw and std manifold
