I know, it is either that or we raise the car up 10mm and stiffen the shocks right up.
Want to borrow my Nitrons?
F-U-C-K Off
Posted 13 May 2012 - 07:32 PM
Posted 13 May 2012 - 07:33 PM
Posted 13 May 2012 - 07:39 PM
Posted 13 May 2012 - 07:56 PM
Posted 13 May 2012 - 08:00 PM
Posted 13 May 2012 - 08:03 PM
The clicks on my Nitrons were erratic from day 1. IIRC both rears were serviced due to loss of clicks and the rear o/s was again rebuilt when the adjuster started sticking at last years National. The whole lot were presumably rebuilt when they were revalved when I had softer springs fitted. In my experience they are not a fit and forget item.
Posted 13 May 2012 - 08:06 PM
Now now Steve, I think you're forgetting the something from the National and the issue you had with your shocks.....?
I remember helping you out with them and can confirm 100% the knob was siezed solid..... I remember you with the mole grips hanging off them Remember why though....? Oh yeah; you were spinning it the wrong way...... You wound it right back past fully soft and jammed the knob I've told nobody about this until now as I promised you at the time but you just forced my hand
Posted 13 May 2012 - 08:41 PM
Phew... thank goodness for that, I thought for a minute someone had problems with a set of Nitrons!
carry on
Posted 13 May 2012 - 09:22 PM
Woah, 500/700?
I thought I had stiff springs at 475/550, 700 must be solid.
Posted 14 May 2012 - 08:02 AM
carry on
Lets not kid ourselves, I bet Nitron do get issues and returns etc but it's not common
Posted 14 May 2012 - 08:29 AM
That's we thought at the time. Once I was out of panic-mode it was clear that it had jammed in the middle and not at the end. It happened again before I went to Le Mans which led to it going back for a rebuild.I remember helping you out with them and can confirm 100% the knob was siezed solid..... I remember you with the mole grips hanging off them Remember why though....? Oh yeah; you were spinning it the wrong way...... You wound it right back past fully soft and jammed the knob I've told nobody about this until now as I promised you at the time but you just forced my hand
Edited by VIX, 14 May 2012 - 08:31 AM.
Posted 14 May 2012 - 09:31 AM
Edited by chris_uk, 14 May 2012 - 09:33 AM.
Posted 14 May 2012 - 09:53 AM
Can a mod split this nitron/gaz crap and put it in its own thread or merge it into one of the many others?
I wanna read about mikes car and his progress not pages of bickering about gaz and nitrons issues.
Posted 14 May 2012 - 10:22 AM
Posted 14 May 2012 - 11:45 AM
I'm running 875lb springs on the rear and 750lb springs on the front, along with a very stiff Pilbeam ARB on its stiffest setting and there was talk of having to go higher still after Cadwell.
Posted 14 May 2012 - 12:11 PM
Posted 14 May 2012 - 12:13 PM
Just for the record, I was def joking.
Although my Nitrons are 500F/700R so are prob stiffer as needed.
Posted 14 May 2012 - 12:59 PM
What a great Idea,
