Hi Jamie,
450 Front 550 Rear I have to confess, I like it a bit softer (ooerr missus).
Should I just go stiffer all round?
I have some 650's in the loft I think. You want a borrow?
Posted 14 May 2012 - 01:41 PM
Hi Jamie,
Posted 14 May 2012 - 01:47 PM
Posted 14 May 2012 - 01:49 PM
Posted 14 May 2012 - 01:53 PM
Posted 14 May 2012 - 02:00 PM
Posted 14 May 2012 - 02:16 PM
Posted 14 May 2012 - 02:19 PM
Posted 14 May 2012 - 02:24 PM
Posted 14 May 2012 - 02:27 PM
Posted 14 May 2012 - 02:41 PM
Posted 14 May 2012 - 02:47 PM
Posted 14 May 2012 - 02:48 PM
Posted 14 May 2012 - 02:52 PM
Mike, what springs are you on out of interest then? That rear wing of your is big and must be pulling the back end right down. I'm running 875lb springs on the rear and 750lb springs on the front, along with a very stiff Pilbeam ARB on its stiffest setting and there was talk of having to go higher still after Cadwell.
Before we took a bit of wing angle off mine at Cadwell, you could actually see the whole car going into compression down the pit straight. Of course this is fine if you have the dampers and springs to control it and the power to drive through it.
Posted 14 May 2012 - 03:14 PM
Posted 14 May 2012 - 03:32 PM
Can a mod split this nitron/gaz crap and put it in its own thread or merge it into one of the many others?
I wanna read about mikes car and his progress not pages of bickering about gaz and nitrons issues.
What a great Idea,
Hang on a mo guys before you take this 'holier than thou' approach this is Mike's thread and he was just as involved in the discussion as anyone else (he's still commenting on it today, but I'll be the bad guy if I respond.....?).
Additionally I notice every one of you guys calling for an end to the back and forth are the same people who've bought/are buying the Gaz mono's so hardly impartial regardless of how magnanimous you try to portray yourselves. Chris you yourself joined the 'bickering' so it sticks in my throat to hear you condemn it as if you were not involved.
I suggest if you want to read less about the subject we drop it.
Posted 14 May 2012 - 03:46 PM
Posted 14 May 2012 - 04:07 PM
You spoke to Jon lately about that?
Posted 14 May 2012 - 04:08 PM
Posted 14 May 2012 - 04:09 PM
T1rs
Posted 14 May 2012 - 04:13 PM
