#161
Posted 23 December 2011 - 10:05 AM
#162
Posted 23 December 2011 - 10:08 AM
I'm running 2.25deg -ve camber on the fronts, are you looking for more than that?
yes , and max castor
#163
Posted 23 December 2011 - 10:26 AM
#164
Posted 23 December 2011 - 02:00 PM
#165
Posted 23 December 2011 - 02:13 PM
If it were me, I'd remove the the layer of powdercoat on those rear hubs where the brakes mount. The calipers could possibly get hot enough to transfer enough heat across to melt the coating, which could then lead to the bolts loosening off slightly. Might be fine though, but I wouldn't take the risk.
Cheers Jamie, I intend on getting them cleaned up before I fit which will mean the removal of some coating on contact areas including brake mounts and camber shim face.
#166
Posted 30 December 2011 - 06:15 PM
#167
Posted 30 December 2011 - 06:21 PM
Hell, this will be a new car when it is finished.
And probably put together better than when it left the Norfolk Farmers!
#168
Posted 30 December 2011 - 06:40 PM
#169
Posted 30 December 2011 - 06:43 PM
#170
Posted 30 December 2011 - 07:54 PM
#171
Posted 30 December 2011 - 07:58 PM
#172
Posted 31 December 2011 - 05:54 PM
First job was to get the Duralec out and cover the mating faces of the rear subframe and plates and get it fitted up.
#173
Posted 31 December 2011 - 05:57 PM
Here is the drivers side fitted up.
Just time to finish off before it was my Ollie shift.
#174
Posted 31 December 2011 - 06:03 PM
#175
Posted 31 December 2011 - 06:04 PM
#176
Posted 31 December 2011 - 06:06 PM
#177
Posted 31 December 2011 - 06:07 PM
Anti corrosion treatment for aluminium.Excuse my ignorance but what is Duralec?
#178
Posted 31 December 2011 - 06:13 PM
Its a coating that is used between two different metal surfaces to prevent anodic corrosion.
It also works very well in normal corrosion prevention.
#179
#180
Posted 31 December 2011 - 06:18 PM
Thanks
Bing (1)
