Turbo Time Attack 2012
#41
Posted 05 January 2012 - 12:53 PM
#42
Posted 05 January 2012 - 01:12 PM
#43
Posted 05 January 2012 - 01:22 PM
Latest design of manifold, given the C20LET and Z20LET are so similar and all the work is done by hand by him , apart from the plenum, really should be a problem to mount the plenum facing opposite.
sorry to hear about the fire!
this looks shiny, but doesn't look very good for even flow flow distribution butween the runners TBH.
#44
Posted 05 January 2012 - 01:27 PM
a pic of the plenum interior, you can see the velocity stacks , afaik race engines that have been design by cosworth that are turbo'd they use trumpets that protrude into the plenum
#45
Posted 05 January 2012 - 01:47 PM
#46
Posted 05 January 2012 - 05:16 PM
#47
Posted 05 January 2012 - 05:36 PM
#48
Posted 05 January 2012 - 07:15 PM
as a comparison, with an upright throttle body, EDS int manifold
This looks far better for even charge distribution. Have a look at the FPA inlet. This uses a cone-slot-plenum to ensure even charging. I did a lot of research into this ages ago and can look out some dimensions if you need.
I can lend you an engine crane but I'm a looong way from you. Useful if you know anyone travelling around but otherwise completely useless.
ETA
http://media.photobu...66/DSC00613.jpg
Edited by FLD, 05 January 2012 - 07:18 PM.
#49
Posted 06 January 2012 - 08:38 AM
How come you lot run really baby tbs? Is it because the pressure is much higher?
I hardly know anything about tubbies.
On an N/A as long as you get equal MAP to atmosphere when at WOT then its big enough.
#50
Posted 06 January 2012 - 09:22 AM
this is a side entry Cosworth IM, its a interesting layout
in situ
#51
Posted 06 January 2012 - 09:42 AM
ETA
would be good to see the tapered cone details , looking within the insides of the plenum to see if they have wave guide vanes, pulse tuning
I appreciate the offer of the crane, the problem is lack of a workshop, otherwise I would nip out to toolstation and get one.
#52
Posted 06 January 2012 - 12:01 PM
full engine build here ( http://www.motoiq.co...attack-evo.aspx )
#53
Posted 06 January 2012 - 12:48 PM
The cosworth one is also a type of double plenum and would achive a similar flow distribution to a cone and slot arrangment.
Main issue with a side entry is that all in most of the other LET engine installations then it would need to enter from the other side than the VX, which is IMO why Klassen and EDS have stuck to central entry.
Edited by Winstar, 06 January 2012 - 12:49 PM.
#54
Posted 07 January 2012 - 07:32 AM
#55
Posted 14 February 2012 - 02:07 PM
completely rebuilt turbo and remachined k06 compressor wheel, good for 35 lb/min
#56
Posted 14 February 2012 - 03:24 PM
#57
Posted 14 February 2012 - 03:29 PM
Is that a Santa outfit on your chair Steve?
Is TA still on for you?
nope, TeamVXRacing jackets.
TA is an ongoing work in progress
#58
Posted 14 February 2012 - 08:00 PM
Let me know if there is owt I can do.
#59
Posted 13 March 2012 - 12:33 PM
Gearbox #3 ready to get checked over
#60
Posted 13 March 2012 - 01:11 PM
Good news , we now have electrical supply connected to the mains , the decorators and plasterers are progressing well. But contractors still have not started work on the exterior fire damage, so its still weeks away from handover. So that means I am/am not (delete as applicable Steve) competing in Time Attack this year.
