Jules_S Tinkering
#221
Posted 11 April 2013 - 11:19 AM
#222
Posted 11 April 2013 - 03:34 PM
#223
Posted 11 April 2013 - 08:42 PM
#224
Posted 20 April 2013 - 09:04 PM
Back to not thinking about it again
And back to thinking about it
I've watched enough videos now to consider some DIY, in fact I'm quite looking forward to some bodging
Got pretty much everything I need for a start, I'm absolutely determined not to rush and stress myself about this as that's the single most thing I find frustrating about doing stuff on this car......
Off to do some more searching in the short term, as I believe Fiveoclock suggested some bonding agent for the ally reinforcement that may work better than Tigerseal
#225
Posted 20 April 2013 - 09:09 PM
#226
Posted 20 April 2013 - 09:51 PM
#227
Posted 20 April 2013 - 10:11 PM
Jules,
I'm going through the same process myself. I've repaired one sill so far and just in the middle of repairing the front clam this weekend. Let me know if I can be of any help.
As for the aluminium backing, I suggest using quick dry filler, this is because it's only needed to lay up the wet fibreglass, once the fibreglass has set that will be the structural part.
Thanks for that
I've never ever even once laid any fibreglass, but a £700 quote has made me focus somewhat
The current plan is to cut back everything square, as at the moment the vertical hole is about 2" wide and then it flairs back underneath to 3.5" (I love mixing imperial and metric lol)
Sand back the cill at a 2" chamfer away from the 'hole', fix (with whatever) the alloy reinforcement and then cut the fibre one inch bigger either side leaving a 1 inch margin/overlap
Sound about right?
#228
Posted 20 April 2013 - 10:54 PM
#229
Posted 21 April 2013 - 01:48 PM
1. Use a sanding disk on a dremel to remove all the fluff, drill small holes at the end of any cracks, use a hacksaw blade or dremel disk to fully cut out the crack.
2. Support the two ends to they don't flex while being fibreglassed together. With the sills (or anything you can't get to the back of) I suggest using filler to bond in some aluminium mesh, here I can get behind it to i'm clamping some wood behind.
3. Fibreglass over the join (front and rear if you have access to the rear)
4. Sand back using 80 grit sand paper (you'll need a power sander - i'm using a £25 Draper one and it's fine)
5. Skim over the surface with filler.
6. Never follow Stuwy around a corner again.
#230
Posted 21 April 2013 - 01:54 PM
#231
Posted 24 April 2013 - 07:06 PM
#232
Posted 24 April 2013 - 07:49 PM
#233
Posted 24 April 2013 - 07:55 PM
Trolley jacks need to go under the car at 90 degrees, and also need to be able to roll freely whilst lifting and lowering.
Sorry Jules, that isn't supposed to read as wanky as that, just trying to help you maybe work out what went wrong.
#234
Posted 24 April 2013 - 08:02 PM
#235
Posted 24 April 2013 - 08:11 PM
#236
Posted 24 April 2013 - 08:13 PM
#237
Posted 24 April 2013 - 08:18 PM
BTW Where is Matt Bentley based? Does he have a web site? Had a little look the other day and couldn't find anything. My VX could do with
#238
Posted 24 April 2013 - 08:32 PM
#239
Posted 24 April 2013 - 08:37 PM
Based in Kimbolton, around the corner from Elise Parts
Unit 4, Ouse Road,
Bicton Industrial Park,
Kimbolton,
Cambs
PE28 0LP
07436 074786
I noticed the other day that he's signed up as a member on here.
#240
Posted 24 April 2013 - 08:59 PM
