Posted 30 December 2011 - 09:28 PM
Posted 30 December 2011 - 09:50 PM
Posted 30 December 2011 - 09:59 PM
Ohhh they come in the correct Sizes tooo, what they like on price?
JUst looked £650 for a full set (ex vat tho)
They are obviously going to be in a different league to 888's etc!
Go for it, I may join you on that one
Posted 30 December 2011 - 10:01 PM
Posted 30 December 2011 - 10:08 PM
just got some full slicks too,should be fun!!!
Make sure your suspension platform is bulletproof then dude!! The extra G you pull will put the LOT under strain! Beefy HCB's, Toe Links, Spring rates etc!
Where you get them from mate? I've been looking for cheap scrubs everywhere!
Posted 30 December 2011 - 10:12 PM
Posted 30 December 2011 - 10:17 PM
Posted 30 December 2011 - 10:18 PM
Posted 30 December 2011 - 10:19 PM
Posted 30 December 2011 - 10:23 PM
Posted 31 December 2011 - 08:33 AM
I've got a set of part worn 17s. Dunlop 640 iirc? Equiv 225/45/17 (mx5 britcar tyres).
Anybody want em?
they would be ideal for anyone who uses 17s all round.
They come from one of Britcar teams and have lots and lots of meat left on them. Took a while to blag too.
Posted 31 December 2011 - 09:42 AM
Posted 31 December 2011 - 09:54 AM
Posted 31 December 2011 - 10:14 AM
does it really make that much difference compared to a cut slick?
Yep, it really does. If a driver is good enough to generate some heat int the tyres anyway
Posted 31 December 2011 - 03:02 PM
Posted 31 December 2011 - 06:03 PM
Posted 31 December 2011 - 07:03 PM
Posted 01 January 2012 - 01:02 PM
I'm yet to see a cracked subframe. They definitely flex big time, which is why I came up with the carbon sheer panel which I use on my car, but I've just never seen one fatigue to the point of cracking. The S1 Elise are far worse for this and I've only ever seen those crack after accidents.
Is that the honeycomb structure on your diffuser...?
Posted 02 January 2012 - 09:00 AM
I've noticed a very slight amount of rear-end steer under power - turns slightly right under power, left on overrun. Only noticeable on a straight road/track. Thought it was a slight amount of play in the mostly new rear bushes (none noticeable on ramp though) but does subframe contribute?
Posted 02 January 2012 - 09:51 AM
When was the car last geo'd? What shocks you on? What bushes did you fit?
Pop your shocks off and check they are set the same (if adjustable), then operated the wishbones through their full sweep (wheels and shocks still off). They should move freely and drop under their own weight
