Mushroom Racing Roof And Rear Cover
Posted 04 January 2012 - 09:21 PM
Posted 04 January 2012 - 09:27 PM
Posted 04 January 2012 - 09:34 PM
Posted 04 January 2012 - 09:35 PM
Edited by ArticMonkey, 04 January 2012 - 09:36 PM.
come ca:
Posted 04 January 2012 - 09:40 PM
Posted 04 January 2012 - 09:45 PM
Posted 04 January 2012 - 09:54 PM
Posted 04 January 2012 - 09:58 PM
Posted 04 January 2012 - 10:03 PM
Needs a central brake light regardless
Are you sure. I asked a similar question and found it to be a grey area.
Posted 04 January 2012 - 10:07 PM
Posted 04 January 2012 - 10:11 PM
Posted 04 January 2012 - 10:12 PM
Posted 04 January 2012 - 10:14 PM
Edited by Baron Von Scubadaddy, 04 January 2012 - 10:16 PM.
Posted 04 January 2012 - 10:27 PM
Posted 04 January 2012 - 10:42 PM
Posted 04 January 2012 - 11:18 PM
Posted 04 January 2012 - 11:42 PM
Vehicles first used on or after 1 January 1971 must be fitted with two obligatory stop lamps.
Additional stop lamps fitted and connected must be tested. Where extra lamps are fitted and there is doubt as to whether they are connected, the benefit of this doubt should be given to the presenter.
therefore if the third brake light is removed then there is no issue,If left in and partially seen by mot tester(through the vents in fibreglass)then its testable. It must work(and not be obscured) unless it can be seen to clearly be disconnected.(ie see wires not plugged in)
That is where I thought we were.
Posted 05 January 2012 - 07:32 AM
I can't use it on my track car because I can't wear a helmet with the hard top on.This really depends on if your car is a track car or a road car.
I found the complete lack of rear visibility on the road in the Exige a pain in the a*se...
This is not a mod i'd want on a road car.
