Battery Isolator Switch
34 replies to this topic
#21 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 15 January 2012 - 11:17 AM
Just get a Dis-car-nect or whatever they're called.
ETA: http://www.passionau...y-terminal.html
Perfect, thanks Matt! I ordered one of these and it looks just the job thumbsup
#22 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 15 January 2012 - 11:33 AM
Just get a Dis-car-nect or whatever they're called. ETA: http://www.passionau...y-terminal.html
Can you Let us know how you get on jj as im in the same position with my battery dying in about a week.
#23 slindborg
Posted 15 January 2012 - 11:47 AM
I don't think that will stop the problems you guys have tbh
#24 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 15 January 2012 - 02:34 PM
Whys that fella?
#25 chris_uk
Posted 15 January 2012 - 03:10 PM
if your not bothered about keeping the time on the radio correct or keeping your stored channels just fit one of those red key jobbies.. (obviously JJJ isnt :P)
#26 slindborg
Posted 15 January 2012 - 04:05 PM
Whys that fella?
Unless you don't fit the fuse, it will always feed power to the car. Those richbrook items are meant as extra immobilisers in that you can't crank with it 'disconnected' but everything else will work lol
#27 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 15 January 2012 - 09:13 PM
If that switch dont work Jimmy then i was looking at theses if thats any help http://www2.westfali...lar_starter.htm
#28 chris_uk
Posted 15 January 2012 - 09:14 PM
should be alright tbh, seen as tho you will want to keep memory on your headunit etc you could do with that extra wire. Jimmy on the otherhand needs no power what so ever so a simple red switch would work fine.
#29 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 15 January 2012 - 09:22 PM
Is a battery charger not an option? Not only does it keep the battery topped up it will make it last longer due to being charged properly (alternators dont charge batteries correctly!)
#30 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 15 January 2012 - 09:30 PM
That richbrook item will completely kill the power as it isolates the battery. I'm not going to loop that extra wire in at all so can't see how it's supplying power to anything :) Charger's not an option as the car lives in a council garage!!
#31 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 15 January 2012 - 09:47 PM
I'm after one of those myself at the moment!
#32 slindborg
Posted 15 January 2012 - 10:46 PM
I'd consider a new battery if I were you, a week of alarm and radio shouldn't be enough to kill a healthy battery.
Jimmmmer has probably left something on in his lol
#33 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 15 January 2012 - 10:49 PM
A week.... Mines been in the garage since October. It's on a SORN so can't do any road miles. I've been running it though Joe (before he tells me off :lol: ).
#34 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 15 January 2012 - 11:17 PM
It was a brand new battery last year so maybe it's a duff one. Might see if I can get a replacement one.
#35 Baron Von Scubadaddy
  • 6,644 posts
Posted 16 January 2012 - 12:11 AM
I have the red hella battery switch fitted to my dash it works really well. Car left in garage for 18 months nearly switch off returned 18months later turned red key waited for alarm to reset pressed button fob alarm off press the starter off she goes I learnt this with the silver one after going away for a month and returning to a flat battery then jumped it fcuked the ecu £££££££ later every thing good So first thing I did when I got this one was get plans to fit the big red key now it never drains !!!! Cliffie will back this up he was there when it was started.
