Posted 14 January 2012 - 07:27 PM
Posted 14 January 2012 - 07:46 PM
Posted 14 January 2012 - 07:57 PM
Take a look on Ebay. Think there's a set of these knobs on there.
Hi thanks for the sugestion, i have had a look, can't see any, but really need to know if the direction dial is stuck and how to fix that and how to remove the broken shafts. Many thanks Paul
Posted 14 January 2012 - 08:21 PM
Posted 14 January 2012 - 10:19 PM
Sorry mate. I only know how to buy stuff. I've never actually fitted anything. Or made anything work.
I used to be known as the mechanical grim reaper. That was before the break up.
My advice is to sell the damned thing, before it gets a hold on you. Ruined everything I was, it did.
Damn you, Vauxhall. Why, oh why?
Anyway.... This being the VX220.ORG someone useful should be along in a moment. I'm certain they'll be able to help you.
Have a great Sunday.
Have you tried therapy........?
Posted 14 January 2012 - 11:28 PM
Yep, he tried it. His therapist is now in therapy.
Posted 14 January 2012 - 11:38 PM
Dash Removal / Replacement
And check that when you turn the knob that the teeth locate in the gear properly making it turn. If that doesn't work its time to remove the heater box.
Posted 15 January 2012 - 02:51 AM
Posted 15 January 2012 - 10:45 AM
Posted 15 January 2012 - 03:22 PM
Posted 15 January 2012 - 05:53 PM
Posted 15 January 2012 - 08:04 PM
Try drilling a small hole in what's left of the shaft and then screw in a small self tapping screw into the hole.
Hold the knob tightly in a soft jaw vice (or similar) and using mole grips on the screw head pull hard and you "should" be able to extract the shaft.
Ensure that the hole you drill is compatable with the size of screw you plan to use.
Chaz.
Thank you - I'll give it go........next weekend.
Posted 15 January 2012 - 10:02 PM
Posted 15 January 2012 - 10:21 PM
A new heater control panel isn't expensive. Part number is 9197455 and costs about £34 from a dealer. This should have the shafts attached so reuse your old knobs ( ) after extracting the broken bits of shaft from them.
Might be able to find you a new heater panel for about a tenner (plus postage). If you're interested drop me a pm. .
Hi have pm'd may not be as straightforward. Cheers Paul
Also tagged with one or more of these keywords: Heater
General Discussion →
Tuning & Modifications →
Heater PipeStarted by apple2000 , 05 Apr 2020 heater |
Heater SpeedStarted by apple2000 , 16 Apr 2018 heater |
The Market Place →
Car Parts For Sale →
Seats, Heater And FootrestStarted by garyk220 , 13 Apr 2017 biscuit seats, heater, footrest and 1 more... |
The Market Place →
Group Buy Room →
New T7Design Heater For The Vx220Started by 'Buchos' , 05 Mar 2017 heater, fan, hot, cold, air and 5 more... |
VX220 Discussion →
Yet Another Heater Mod ? Sort OfStarted by martinroger , 28 Nov 2016 heater, mod |
