Removing A Drive Shaft.
19 replies to this topic
#1 SteveA
SteveA
  • 9,156 posts
Posted 28 January 2012 - 05:59 PM
I'm replacing the PS drive shaft seal on my VXT. I have the wishbones off, caliper removed and am set to remove the drive shaft. I've tried pulling (from the inside part closest to the Gearbox) it out but can't move it. Do I have to do anything else or is it just a case of putting more oomf into it? Cheers Steve
#2 The Batman
Posted 28 January 2012 - 06:01 PM
use more oomf or a crowbar
#3 CocoPops
CocoPops
  • 17,182 posts
Posted 28 January 2012 - 06:03 PM
A large pack of oomf? Is that available at Screwdix Direct? Or B&Q?
#4 GeorgeBC
GeorgeBC
    Needs a cheaper hobby
  • 3,138 posts
Posted 28 January 2012 - 06:06 PM
You need to give the cv joint a tap use a piece of wood so you dont damage it or lever it out with a screwdriver to pop them out of the box
#5 SteveA
SteveA
  • 9,156 posts
Posted 28 January 2012 - 06:09 PM
Cheers gents, I'll give the CV a tap with my rubber mallet and get a lever in there. Thanks for the quick response thumbsup
#6 vocky
Posted 28 January 2012 - 06:14 PM
crowbar every time :sleep:
#7 bunsenburner
bunsenburner
  • 1,042 posts
Posted 28 January 2012 - 06:46 PM
Watch out for the gearbox oil that will p*ss out once the shaft is removed. Jacking up the car a high as you can will prevent a big flow thumbsup
#8 SteveA
SteveA
  • 9,156 posts
Posted 28 January 2012 - 08:51 PM
And it's out. Is it just me or does VXL OEM GB oil smell like cheap red wine :) Just the easy job of removing the seal now. So far I've mangled most of it and it hasn't budged grr!
#9 vocky
Posted 28 January 2012 - 09:07 PM
big screwdriver and just lever it out
#10 SteveA
SteveA
  • 9,156 posts
Posted 28 January 2012 - 09:22 PM
Got that out now too. Any idea why there would be a thin long spring around the inside circumference of the seal? Can't see in on the EPC.
#11 vocky
Posted 28 January 2012 - 09:25 PM
part of the seal
#12 SteveA
SteveA
  • 9,156 posts
Posted 28 January 2012 - 09:34 PM
Nice one, was a little worried there. Guess I'll see it when my new seal gets delivered on Monday. Cheers Vocky thumbsup
#13 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 28 January 2012 - 09:59 PM
It's a varilip seal thumbsup
#14 SteveA
SteveA
  • 9,156 posts
Posted 30 January 2012 - 09:48 PM
Right, i've ruined one new seal trying to fit it in. Only cost me 99p so no big deal and have just ordered another. Any ideas on how I can get it in without damaging it? Tried the socket thing but a 32mm one isn't quite big enough, I think I might have to buy a 42mm one. I was wondering if there is any clever way to keep it in place before I push it in.
Edited by SteveA, 30 January 2012 - 09:48 PM.
#15 vocky
Posted 30 January 2012 - 09:51 PM
you just need something which fits over the seal, socket, metal pipe etc
#16 SteveA
SteveA
  • 9,156 posts
Posted 01 February 2012 - 02:04 PM
Thankfully I work for a company with a large marine engineering department and have favours to call in. The guys are making me a custom tool to do the job FOC thumbsup
#17 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 02 March 2012 - 02:15 PM
rats didn't have a big enough socket so it went in crocked, have to replace it
#18 SteveA
SteveA
  • 9,156 posts
Posted 02 March 2012 - 02:25 PM
I have a spare which I would offer to you but I'm changing my drive shaft early next week and want to hold onto it just in case. If I don't need it you can have it FOC but it won't be till Wed at the earliest. 46mm is the smallest you can get away with, I recon a 48mm might be a bit better fit though.
#19 Nev
Posted 02 March 2012 - 03:30 PM
Scaffold pole is the exact correct size to tap the gearbox seal in with. Ask a scaffolder for a 6 inch cut off from one of his poles :)
#20 The Batman
Posted 02 March 2012 - 03:37 PM
nice tip, i will grab an off cut from work
