Front Caliper To Rear Adaptor Bracket
243 replies to this topic
#81 Steffen
Steffen
  • 286 posts
Posted 08 May 2012 - 12:50 PM
Brackets are ready again.
#82 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
  • Interests:Performance cars!
Posted 08 May 2012 - 02:44 PM
I like mine...with the hispecs the piston area ratio is very close to original and it stops werry werry well.
#83 Steffen
Steffen
  • 286 posts
Posted 10 May 2012 - 07:39 AM
I wanted to ask if there is someone who has taken the brackets and not convinced of the better braking performance?
#84 Steffen
Steffen
  • 286 posts
Posted 28 May 2012 - 07:17 AM
Still available
#85 robin
robin
  • 3,810 posts
Posted 28 May 2012 - 06:13 PM
has anyone had problem of the rear wheels making contact with the calipers when fitted?
#86 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
Posted 28 May 2012 - 06:52 PM
Mine are close...stock rear wheels. What wheels?
#87 robin
robin
  • 3,810 posts
Posted 28 May 2012 - 07:09 PM
compomotive wheels it just snags rear calipers so think ill need some wheel spacers
#88 Glambee
Glambee
  • 104 posts
Posted 28 May 2012 - 08:53 PM
Did somebody find a smaller caliper than the Brembo one to keep the handbrake?
#89 Steffen
Steffen
  • 286 posts
Posted 29 May 2012 - 06:24 AM
I'm working for it. When it will be ready it will be a handbrake which will be "plug and play" in the position of the original brembo with a weight of 600 gramms.
#90 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
Posted 29 May 2012 - 06:54 AM
Nice!
#91 Steffen
Steffen
  • 286 posts
Posted 02 July 2012 - 07:36 AM
Like written before.
Edited by Steffen, 02 July 2012 - 07:37 AM.
#92 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
Posted 02 July 2012 - 07:46 AM
Oooh!! Nice. Do you have more details and price?
#93 Steffen
Steffen
  • 286 posts
Posted 02 July 2012 - 08:01 AM
It's a Hispec-handbrake with some mods from me. I use the mechanical part the outside part and the 2 distances from the Hispec. The inside part (you see this on the last foto) is from me, to come in the correct position and to fit directly without any adaptor. There are also the fittings and distances to use the original cable. There are still 2 problems to solve. 1. The cable doesnt turn back after using the handbrake. position and dimension for the spring is found. 2. The angle of the mechanic part and the cable is no the same. I think everything will be solved until next saturday. Then i can give also the price for the kit, which will be complete plug and play.
Edited by Steffen, 02 July 2012 - 08:02 AM.
#94 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 02 July 2012 - 10:22 AM
Would be interested in the handbrake caliper spot on :-)
#95 techieboy
Posted 02 July 2012 - 10:31 AM
Good work. Keeping the OEM Brembo caliper has always been a stupid option when fitting the front caliper on the rear and is just a waste of weight.
#96 JG
JG
  • 13,612 posts
Posted 02 July 2012 - 10:57 AM
esp as they weigh a ton, much more than the fronts.
#97 Steffen
Steffen
  • 286 posts
Posted 02 July 2012 - 01:19 PM
I agree!
That was the motive to find this solution!
#98 Steffen
Steffen
  • 286 posts
Posted 30 August 2012 - 06:40 AM
Handbrake will be ready in some weeks. Brackets are available.
#99 kipper
kipper
  • 2,364 posts
    Smoking various types
    of fish.
Posted 04 September 2012 - 10:00 PM
OK Steffen, I would be interested in the Handbrake. Keep us posted. Regards Dave
Edited by kipper, 04 September 2012 - 10:01 PM.
#100 Steffen
Steffen
  • 286 posts
Posted 05 September 2012 - 07:00 AM
Ok. Will post it when I will start with the production.
