Front Caliper To Rear Adaptor Bracket
243 replies to this topic
#141 SteveA
SteveA
  • 9,156 posts
Posted 25 April 2013 - 02:49 PM
Going out and testing combinations is going to be key. National brake testing laps? ;)
You might want to save that for a airfield day.
#142 SteveA
SteveA
  • 9,156 posts
Posted 06 May 2013 - 12:23 PM
I have a set of these that I bought from Steffen that were never fitted and I have no use for them now so will be selling them on. Sorry to hijack your thread Steffen :blush:
These have been sold btw.
#143 Steffen
Steffen
  • 286 posts
Posted 07 May 2013 - 12:38 PM
Since yesterday the handbrake solution on my car is ready. It's still a prototyp but there are only details to solve. The power is now strong enough. It isn't anymore, like in the beginning of the project, a modified Hispec brake. We produce the brake completly by our self. Think we will be ready for sell the solution at the end of may.
Edited by Steffen, 07 May 2013 - 12:38 PM.
#144 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
  • Interests:Performance cars!
Posted 07 May 2013 - 02:43 PM
Good effort!
#145 redvts
redvts
  • 1,472 posts
Posted 07 May 2013 - 04:04 PM
Good news :) Any idea on the price?
#146 Steffen
Steffen
  • 286 posts
Posted 08 May 2013 - 10:09 AM
Price is still to decide. It is very important to know how much pieces we can produce, if there are only 20 pieces the price will be not so good, if we can make 50pieces it will be good! Depends very much of the interest in this solution.
Edited by Steffen, 08 May 2013 - 10:12 AM.
#147 fezzasus
Posted 08 May 2013 - 10:22 AM
Ok... 44.5mm front pistons (stock) and 28mm rear pistons (stock) give a 60:40 ratio of braking from front to rear.
Brake area constant 2764, with a 5:1 slave/master ratio.
If you use the "bolt on" ap calipers with asymetric pistons then you should be on 31.75mm/36mm leading/trailing
1008 + 1296 = 2304 ( and 784 rear) This is 16% more braking than standard - if you've gone for 308mm disks thats 21% more braking than standard.
Balance = 64% front to 36% rear.
This is why it upsets bias.
John, Where did you get the measurements for the rear piston? My measurements show it's 36mm, which gives a brake bias of 75/25 %
#148 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
Posted 08 May 2013 - 12:16 PM
I was corrected if you look. Its still 60/40 though, as I used the correct size when i did the calc. You know you only count pistons on one side of the disk? Will avoid a discussion about reaction forces.
#149 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
Posted 08 May 2013 - 12:18 PM
CORRECTED:- Ok... 44.5mm front pistons (stock) and 36mm rear pistons (stock) give a 60:40 ratio of braking from front to rear.Brake area constant 3276, with a 6.2:1 slave/master ratio (higher is spongier but more assisted).If you use the "bolt on" ap calipers with asymetric pistons then you should be on 31.75mm/36mm leading/trailing1008 + 1296 = 2304 ( and 1296 rear) This is 10% more braking than standard - if you've gone for 308mm disks that's 17% more braking than standard.Balance = approx 66% front to 34% rear. 6.8 : 1 slave/master This is why it upsets bias.
#150 fezzasus
Posted 08 May 2013 - 12:41 PM
Cheers John, certainly useful information to have down. I assume for increased disc size you're just calculating increased torque applied by the caliper?
#151 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
Posted 08 May 2013 - 01:30 PM
Sure. ..thats a guess though. Its the centreline of the pad thats important, rather than overall diameter. Ie a massively deep pad radially will actually provide less torque than a shallow one onthe outside edge.
#152 Steffen
Steffen
  • 286 posts
Posted 24 September 2013 - 09:53 AM
Only to get you informed.
We have finished the projekt of the handbrake solution.
We started to sell a 10 couples series yesterday at midnight.
It was sold out this morning.
So here I want only inform you that I will offer them a.s.a.p they are ready again.
Price  £ 295.- including Transport to UK
The calipers are completly plug and play with all items you need to fix them.
of course it will be use the original hand brake cable.
Completly made in aluminium anodized in black.
Edited by techieboy, 24 September 2013 - 10:01 AM.
Fixed image embeds
#153 fezzasus
Posted 24 September 2013 - 10:05 AM
Very nice, do you know of the weight saving in comparison to the Brembo calipers?
#154 Steffen
Steffen
  • 286 posts
Posted 24 September 2013 - 10:22 AM
Brembo 3600gr
AP 1500 gr
Brackets  600gr
Handbrake 600gr
#155 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 24 September 2013 - 08:48 PM
Do you still need the AP bracket adaptor or is this built in?
#156 The Batman
Posted 25 September 2013 - 02:28 AM
Yeah still need them this is merely a spot caliper I really want a set.... Hmmmm....
#157 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 25 September 2013 - 05:36 AM
Can he do a deal on them both then? ;)
#158 fezzasus
Posted 25 September 2013 - 06:46 AM
To put the price in perspective, a single brembo caliper costs the same as a pair of these. If this had come along a month ago I know what I would have gone for.
#159 Steffen
Steffen
  • 286 posts
Posted 27 September 2013 - 09:27 PM
Put you on the list for the next 20 pieces which we are producing now.
I will contact you when they are ready.
#160 Nikov
Nikov
  • 723 posts
Posted 04 October 2013 - 01:01 PM
Can you put me on the list for brackets to mount AP 2 pots plus a pair of spot calipers please?
