#121
Posted 04 July 2014 - 02:28 PM
#122
Posted 04 July 2014 - 03:17 PM
I'm not being a fanny - nowt wrong with my leg muscles as many a shafted young lady will testify!
Re comparisons, I think there is something not right with my car as I've driven another VX it had way better brakes than mine - but, I either upgrade or refurb, and I'm thinking of an upgrade, and the big thing I'm looking for is better bite with lower pedal pressure.
Reading this thread (and others) some people have them and some don't, as this is about brake improvement concensus, yet it doesn't seem to have been established yet!
One thing I have noticed across the threads is that fitting the AP 4 ports is not an improvement, but fitting the racing 4 pots and putting the standard fronts on the rear makes a huge improvement. Is that a concensus those that have tried can agree on? Should I go down that route for a road car, or just refurbish my clearly clapped out 11 year old standard setup?
#123
Posted 04 July 2014 - 06:59 PM
#124
Posted 04 July 2014 - 07:25 PM
I put new discs on when I put the 1155's on and they're still fine. I also had the fluid changed, although it's time to do it again. I think a pad upgrade is worth a try.
#125
Posted 04 July 2014 - 07:31 PM
#126
Posted 04 July 2014 - 07:37 PM
I've had my VX on 6 different tracks and never experienced any braking issues. I've kept things simple, RC5+ pads, RBF600 brake fluid, 4 channel ABS, standard discs and I keep my calipers in tip top order. I generally give up before my brakes do.
#127
Posted 04 July 2014 - 07:52 PM
Are you pressing hard and getting the abs kick in?
The ABS will kick in if I press hard enough, that's the point though, I don't want to have to press that hard.
How are you keeping your calipers in tip top order? Also, if you're giving up, isn't that an indication of pedal effort?
#128
Posted 04 July 2014 - 08:10 PM
#129
Posted 04 July 2014 - 08:11 PM
The front calipers were refurbed by the previous owner, I believe AP Racing do kits for them and that it isn't that difficult to do. The rears are more tricky due to the handbrake mechanism. Kits are available but it is extremely difficult to do. I started doing my rear left and had to admit defeat. I sent it to a caliper refurbisher in the end.
When I say give up, I'm talking about me generally being knackered. I've never felt like the brake pedal is taking too much effort to push. Even at Blyton Park when you are on and off the brakes every 5 seconds I never had any issues with the brakes at all. If any thing, they seem to work better when they are hot.
#130
Posted 04 July 2014 - 08:26 PM
I have to say the 4 channel ABS brain is a huge improvement. Paul
I fitted this recently, and it is an improvement, but not in my case to pedal effort and initial bite.
Ok, so this might be the way forward. I have the kit and a spare pair of calipers, just not fitted them yet. I was wondering whether to fit the kit but stick the calipers on the rear and get some 4 pots. May I ask the name of the firm that did your rears?
#131
Posted 04 July 2014 - 08:37 PM
My brake history -
Standard pads from new. Not very good.
After a year I changed to Mintex 1144, braided hoses and high temp brake fluid. Good improvement.
Next I fitted the AP 4 pots and discs on the front with Pagid RS15 pads and RS15 rear pads. Night and Day difference particularly when brake from high speed.
Last year just before the National I thought I would try 1155 all round. Not a patch on the Pagids.
The ABS has been switched off since I fitted the 1144 and has never been turned off.
#132
Posted 04 July 2014 - 08:39 PM
#133
Posted 04 July 2014 - 08:54 PM
It was this excellent post by dw1 that many refer to and got me thinking.
vi) Do you want better pedal feel? A 4 pot system may help here
He also suggests trying things in stages, which I was hoping to avoid, but maybe it's the very best way forward.
Lesson 5. Modify your braking in stages
If I'm going to do this I'll do in this order: -
1. Refurb my spare set of front calipers and install first - with some braided steel hoses. 2. CL5+ pads.
3. Consider a big brake kit.
#134
Posted 04 July 2014 - 09:14 PM
#135
Posted 04 July 2014 - 09:33 PM
It's just my hoses are ancient and should be replaced really, but yes, I've never noticed any difference when changing over to them on bikes.
#136
Posted 05 July 2014 - 08:13 AM
#137
Posted 05 July 2014 - 09:22 AM
#138
Posted 05 July 2014 - 10:04 AM
I would exhaust every avenue before going for the big brake kit. If your braking system has some sort of issue, a big brake kit will make naff all difference. I have standard calipers front and rear and have never had any complaints. I must of got lucky when I replaced my flexi hoses, no problems what so ever with brake feel since I did it. I only went the braided hose route because it worked out cheaper than OEM hoses. I totally agree that braided hoses make no difference over rubber.
#139
Posted 08 March 2017 - 01:36 PM
Sorry to revive an (excellent) old thread, but was wondering what the options are for rear brake upgrades? The various options for front upgrades are well documented here and elsewhere but there is less info on the rears. I gather it is possible to fit the standard front calipers onto the rear, but then wouldn't you lose the handbrake function?
Obviously you can change the discs/pads etc but was wondering if there are any upgraded rear calipers that allow you to keep the handbrake (and hence pass an MOT)?
Thanks!
#140
Posted 08 March 2017 - 05:57 PM
Thanks!
If you fit the standard front calipers to the rear, then you can fit spot calipers to the rear for the handbrake. Think they wwere sold by Steffen on here?
