As per details on the Forge website and also on the Courtenay Sport website
Designed as a direct replacement for the OEM valve which is prone to failure when the engine has been tuned or had an upgrade to the engine management software.
This valve is complete and ready to install with no fitting kit required. It is available with 3 spring choices depending upon the state of tune of the engine.
Green Spring - For Standard Cars/Standard Boost.
Yellow Spring - For mapped/tuned cars running higher boost.
Blue Spring - Hybrid+ Turbo
Additional Springs available if required.
This valve is suitable for:
- Vauxhall / Opel Astra G or H type Z20LET engine
- Corsa VXR 1.6 Turbo Z16LER Engine
- Vauxhall Zafira A or B with Z20LET engine
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
DG
