Pretty sure I know the answer but just looking for confirmation.
i went to remove the battery this morning, it's totally goosed and not even registering on the trickle charger as being connected, and managed to get the 'almost flat' bolt at the top of the bracket off, one of the lower ones came out relatively easy but the other is just turning. I assume the captive nut has loosened from the chassis and the head of the bolt will need to be ground off?
Battery/washer Bottle Retaining Bracket
Started by
h8ten
, Feb 26 2012 04:07 PM
Battery Washer bottle bracket
4 replies to this topic
Posted 26 February 2012 - 04:07 PM
Posted 26 February 2012 - 04:09 PM
Yep. You might be able to wedge a flat blade screwdriver behind the bracket to add a bit of pressure to the rivnut, which might allow you to undo it. Didn't work for me, so Dremel came out and I then drilled the remains out and replaced the rivnut.
Posted 26 February 2012 - 04:41 PM
I two had this problem last week. In the end i butchered the old bracket to get the battery out and purchased a new bracket. However i retained the old bolt and modified the new bracket to slide over the bolt and used the other two as normall. Job done
There where a few brackets on ebay last week and atomx may still have one, if you go down the route that i did.
Edited by deano01, 26 February 2012 - 04:43 PM.
Posted 26 February 2012 - 05:00 PM
I've also had the same problem - stupid captive nuts!
Posted 02 March 2012 - 04:27 PM
'Dremelled' the spinning bolt out and once the battery was out I checked the voltage. It was reading 4.9v but dropping and that was only the multimeter connected. Put the charger on it, it needs to have 2v to be able to attempt recovery. After a day charging and up to 12.7v the charger was showing an error code. This code refers to an 'Internal Open Cell' so although it seems to be taking a charge I think it will be just as well to change it for a new battery.
Also tagged with one or more of these keywords: Battery, Washer bottle, bracket
The Market Place →
Car Parts Wanted →
Itg Filter Bracket KitStarted by Gopherit , 21 Feb 2018 ![]() |
General Discussion →
VX220 Discussion →
Miniature Car Battery Emergency Booster.Started by RabnaKS , 29 Feb 2016 ![]() |
VX220 Users Gallery →
Fog Light - Drl ConversionStarted by james.a , 29 Feb 2016 ![]() |
VX220 Discussion →
Battery Problem - Advice PleaseStarted by Tony VXR 56 , 13 Mar 2014 ![]() |
The Market Place →
Car Parts Wanted →
Battery Clamp / Washer Bottle BracketStarted by Vaux Pop , 06 Mar 2014 ![]() |
