Gaz Gold Pro Coilovers - Feel Like Swearing!
#21
Posted 16 March 2012 - 08:37 PM
#22
Posted 16 March 2012 - 08:42 PM
#23
Posted 16 March 2012 - 08:44 PM
#24
Posted 16 March 2012 - 08:48 PM
#25
Posted 16 March 2012 - 08:52 PM
#26
Posted 16 March 2012 - 08:55 PM
Id get rid of that elise lowering suspension mountings..
My thought too.
Surely you would have to compress the springs to raise the car to the height Sol is looking for?
#27
Posted 16 March 2012 - 08:59 PM
#28
Posted 16 March 2012 - 09:00 PM
#29
Posted 16 March 2012 - 09:01 PM
#30
Posted 16 March 2012 - 09:06 PM
JG and I fitted my GGP within an hour or 2 one afternoon.
All fitted, set up and ride height adjusted.
It's not difficult, so I suggest if you are struggling that you take Mike up on his offer of help.
But neither of you have lowering brackets though IIRC
#31
Posted 16 March 2012 - 09:10 PM
Didn't i do most it?
#32
Posted 16 March 2012 - 09:11 PM
correct
#33
Posted 16 March 2012 - 09:17 PM
Sol, I have offered to help and I am full of compassion but I can only help those that are willing to listen.
I would need to understand more about what you modified to fit 195/17' on the front and you mentioned elise lowering brackets, both are things that may be affecting your set up and ultimately your handling.
It is an impossible question to answer on a forum as there are too many variables to consider. It is a case of somebody looking at the car to determine the issue or issues. I doubt the Gaz are to blame, I would suggest (if I may) that either a non knackered set of shocks that (maybe, if iam allowed to say that) have been fitted incorrectly have highlighted or even amplified another area.
As I say, impossible to know without looking at the car.
#34
Posted 16 March 2012 - 09:22 PM
Some people you can't help.
I am sure Gaz will react in the same way I have and without a Geo you cannot blame the shocks.
This.
#35
Posted 16 March 2012 - 09:28 PM
#36
#37
Posted 16 March 2012 - 09:35 PM
Sorry pushed the wrong button, I didn't mean to re-send Cliffie post.
All please forgive me for targeting most of my posts to Cliffie it's just that I see him as an expert on the Gaz coilovers. No disrespect to anyone else.
Cliffie, I did appreciate your offer to look at the car but I didn't want to put you to that trouble.
I'll put the Gaz back on in the morning, set the ride height to 125 front, 135 rear, bump and rebound from soft 5 clicks rear, 4 clicks front.
Hopefully It'll be good enough to get to to work next week.
I have a service and MOT booked for Friday. If the car is reasonably drive able I'll ask the service centre to look at the suspension.
If it drives really bad I may rob the shocks from my sons VX220 for the MOT.
Wish me luck.
Sol
Best of luck with it fella, the offer stands right up until my VX comes back from the cage work then I will be flat out till the end of the season.
#38
Posted 16 March 2012 - 09:36 PM
#39
Posted 16 March 2012 - 09:37 PM
Wish me luck.
Sol
Ditch the lowering brackets....zero pre-compression on the springs and you will be circa 125mm on the front
4 clicks from soft and I'm guessing you will be 100% more pleased with it all.
#40
Posted 16 March 2012 - 09:40 PM
Wish me luck.
Sol
Yeah that, Amen.
