I've had a bmc carbon dynamic airbox induction kit on a couple of previous vehicles and now fancy fitting the larger (150mm) diameter one on my VXT (currently have a k&n panel in the standard airbox with no AMM issues). It's improved the sound and, I felt, throttle response. So, what are peoples opinions?
I've done a bit of a search with not much success, although no-one appears to have had AMM issues with one so far from what i gather.
Is it easy to fit?
Any reducers required to fit it to the throttle body- if so what size?
Opinions in general?
Many thanks for any help.
I've got to remove the rear p/s wheel to replair my abs sensor anyway so may take out the arch liner and give it a go while i'm at it!
