Chris Tullett Exhausts
246 replies to this topic
#101 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 14 April 2012 - 10:08 PM
thumbsup
#102 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 14 April 2012 - 10:51 PM
Yes but the air box is no where near the heat and will be taking in forced air from the vents.
Look in the forsale section for nimbus heat shield. You will need this as you loose the OEM shield when fitting the manifold (go halfs with you). :happy:
Works for me.. Pm sent
#103 yaaan
yaaan
  • 956 posts
Posted 14 April 2012 - 11:30 PM
Is it worth letting the GB run to the end of the month, or is it worth concluding the GB and getting the order in to Chris Tullett?
If you could possibly hang on for a day or so I may well be interested in the manifold but need to speak to Liam this week first and see how/if the 2bular one is progressing. If there's no joy there I'll be in :)
#104 14500rpm
14500rpm
  • 381 posts
  • Interests:Boobs, Cars. Motorcycles.
Posted 15 April 2012 - 12:50 AM
I'm in for a 2.5 manifold and 200 cell cat/down pipe (assume these are the NA ones?)
#105 PHB1969
PHB1969
    Premium Member
  • 946 posts
Posted 15 April 2012 - 07:11 AM
No problem - end of next week ok?
#106 PHB1969
PHB1969
    Premium Member
  • 946 posts
Will add you to the list - thank you
#107 Tommo
Tommo
  • 344 posts
Posted 15 April 2012 - 03:29 PM
I'm ready to go whenever you guys are. although I'm not looking forward to taking the clam off to fit the manifold though!!
#108 smiley
Posted 15 April 2012 - 03:55 PM
Sliding it back 10cm could be enough.
(still requires all bolts loose though)
#109 Tommo
Tommo
  • 344 posts
Posted 15 April 2012 - 04:00 PM
I've a light metallic rattle back there somewhere anyway (Possibly a heat shield of some description) so ill whip it off and search for that as well while I'm at it.
#110 PHB1969
PHB1969
    Premium Member
  • 946 posts
Posted 15 April 2012 - 04:03 PM
The updated list:
1) Big_bazza99 - 2.2NA Manifold, 200 cell downpipe & re-packable silencer
2) Chris P Duck - 2.2NA Manifold
3) ArticMonkey - 2.2NA Manifold
4) Tommo - 2.2NA manifold, 200 cell down pipe and silencer
5) Bargi - 2.2NA Manifold
6) johnnyn - 2.2 Manifold (z22se.co.uk)
7) jazzmaster - 2.2NA Manifold & 200 cell down pipe
8) Ciderbooze - 2.2NA manifold, 200 cell down pipe and silencer
9) cthomas443 - 2.2NA manifold, 200 cell down pipe
10) MikeyVX - 2.2NA Manifold
11) 14500rpm - 2.2NA Manifold, 200 cell down pipe
Thank you
#111 TazN
TazN
  • 2,931 posts
Posted 15 April 2012 - 06:09 PM
Still waiting on my system... over a month :/ guess he's rather busy fabricating! I might be tempted on a manifold closer to the end of the gb if I've got the funds spare.
#112 SpeegyVX
SpeegyVX
  • 14 posts
  • Interests:Fast Lightwieght Sports Cars! & Beer! (mixed together can be pretty dangerous tho!)
Posted 15 April 2012 - 06:36 PM
i dont want the system to be tooo loud so i was planning on fitting the the n/a manifold and the 200 cell CAT but keep the the stock backbox... ...how badly will this restirict the engine? as i dont want to spend all the money to try and gain power if the stock backbox is just going to choke it all... cheers!
#113 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 15 April 2012 - 06:38 PM
cheers!
It will help but you might be best buying a Miltek turbo 2.5" back box to help things.
#114 SpeegyVX
SpeegyVX
  • 14 posts
Posted 15 April 2012 - 08:54 PM
cheers!
is that one of the quieter backboxes then?
#115 14500rpm
14500rpm
  • 381 posts
Posted 15 April 2012 - 09:43 PM
cheers!
I'm going to get a 2.5" U-pipe made up to connect mine up to a standard turbo backbox, might need to mod it too but will hopefully keep it quiet.
#116 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 16 April 2012 - 06:13 AM
cheers!
Yep, correct
#117 Sammy
Sammy
  • 1,206 posts
Posted 16 April 2012 - 06:24 AM
I think I'll kick myself if I don't put myself down for this. Will work out what to do with it later. :P
12) Trifid - 2.2NA Manifold, 200 cell down pipe
#118 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 17 April 2012 - 04:59 PM
Anyone else down south on this GB? If so anyone wanna meet up and tackle fitting of both at the same time?
#119 vocky
Posted 17 April 2012 - 05:02 PM
you can fit the tullet maniold with the clam in place, but it's damn awkward and the downpipe must be off for access
#120 Sammy
Sammy
  • 1,206 posts
Posted 17 April 2012 - 06:12 PM
I may be up for that. I was just going to buy it and put it in the shed until I worked out what to do with it! Probably would have taken it to PSR to do...
Is a heat shield/wrap necessary?
I thought the NA one is a direct bolt on for standard systems?
