Is a heat shield/wrap necessary?
you can either modify the original heatshield to fit (hammer abuse), fit some nimbus to the clam (instead of that crap silver plastic) or wrap the manifold
Posted 17 April 2012 - 06:14 PM
Posted 17 April 2012 - 06:17 PM
Posted 17 April 2012 - 06:25 PM
although I'm not looking forward to taking the clam off to fit the manifold though!!
Sliding it back 10cm could be enough.
(still requires all bolts loose though)
Anyone else down south on this GB? If so anyone wanna meet up and tackle fitting of both at the same time?
I may be up for that. I was just going to buy it and put it in the shed until I worked out what to do with it! Probably would have taken it to PSR to do...
Posted 17 April 2012 - 06:49 PM
Posted 17 April 2012 - 07:03 PM
Would he do any deals on a decat for the 3inch SC system.
the crap plastic stuff on the clam deforms due to the heat, all you need is a piece of Nimbus approx 450mm x 300mm to fit over the crap plastic stuff next to the exhaust manifoldAnd none of the above will result in melting the clam (or worse)?
Posted 17 April 2012 - 07:07 PM
Posted 17 April 2012 - 07:08 PM
I can ask - so are you just wanting a downpipe with in 3" with no cat...?
Posted 17 April 2012 - 07:12 PM
Just a bolt on section to replace my cat with, so i can swap and change when i want to.
I think it's the GIINimbus Lite or Nimbus GII or are both equally good?
Posted 17 April 2012 - 07:28 PM
Posted 17 April 2012 - 08:03 PM
Having just bought some from Cliffie, I should have enough left to make another shield to save you buying a big sheet of the stuff.
Posted 17 April 2012 - 09:52 PM
How much will you have and how much would you want for it?
Posted 18 April 2012 - 03:36 PM
Posted 19 April 2012 - 06:56 PM
Posted 19 April 2012 - 07:24 PM
Posted 19 April 2012 - 07:51 PM
Posted 19 April 2012 - 08:38 PM
Posted 19 April 2012 - 08:42 PM
Posted 19 April 2012 - 08:51 PM
