no length has a lot to do with it, as in a lot of cases
James, imagine blowing through straw and then blowing through a hose pipe, what's going to be easier?
resistance overall
I'm still not entirely sure i understand why it needs to be bigger, Is it to reduce flow rate?
but that still doesn't make much sense to me. its open, there is no resistance.
Depends on the bore. Makes no odds on the length as long as there are no kinks or restrictions.
Mine as is Nick's runs over the subframe and out of the rear clam behind the rear wheel.
