Posted 14 April 2012 - 09:37 PM
Posted 14 April 2012 - 09:43 PM
Posted 14 April 2012 - 09:59 PM
Reverse light switch for sure (for the reverse light anyway). You'll need to remove it from the gearbox and you may be able to breath some life back into it with WD40 (didn't work for me) or replace it (which is only about £7).
Fog light not working? Good. They're worse than useless in fog anyway. But, I guess if you're that bothered about it, you'll need to remove it. Relevant headlight out and with lots of cocking about you can get the bulb holder out of the back of the foglight unit and at least check the bulb and the wiring to it.
You missed it when you came over Matt...my nearside fog was moving as above and the entire lower end of the foglight mounting bracket was non existent.
Completely rusted away to nothing.
I'll get a pic up morrow. it's not pretty. if it's a rusted as mine the jacknuts will need grinding off too
I have no fog lights now...as you said they are utterly useless anyway
Posted 14 April 2012 - 10:06 PM
Posted 14 April 2012 - 10:25 PM
The correct tools and replacement fixings are a must when doing such jobs
Posted 14 April 2012 - 10:28 PM
Yep, even now, with just about every nut and bolt on the car replaced during my ownership, I never tackle anything without at least 10 times the number of replacement fixings to hand.
Posted 14 April 2012 - 10:32 PM
Posted 15 April 2012 - 08:10 PM
Also tagged with one or more of these keywords: Not working
General Discussion →
VX220 Discussion →
Hazards Not Working, Help Required.Started by jdscott , 09 Sep 2017 ![]() |
