Strangely I dont mind that. It looks like someone has a 'fun' sense of humour.
Pfft, american hotrod.
Posted 23 January 2014 - 01:30 PM
Posted 23 January 2014 - 03:33 PM
can we have a picture already!
Posted 23 January 2014 - 07:37 PM
Bear in mind everything I've learnt about painting cars has come from watching half a dozen episodes of American Hotrod.
Posted 24 February 2014 - 07:12 PM
Love the look of the car!! Hat off to you sir.
Cannot wait to see finished product if workmanship is anything to go by it will be something truly epic and un matchable!!!
Let's get it finished now though
we want to see it!
Al
Posted 24 February 2014 - 08:05 PM
Posted 24 February 2014 - 08:08 PM
From what little I can see it looks great
Posted 24 February 2014 - 08:09 PM
Posted 24 February 2014 - 08:41 PM
Posted 24 February 2014 - 08:44 PM
Posted 25 February 2014 - 08:14 AM
I'll have to nip round.
Posted 01 March 2014 - 05:16 PM
Are you going to sell the lights in kits? I love the look of it but wouldn't know where to begin.
I can filler and sand so id be ok if you did. Don't need it to bolt on. ha
Al
Posted 06 April 2014 - 12:26 PM
Bump!
Posted 06 April 2014 - 06:21 PM
Posted 06 April 2014 - 09:21 PM
Lol my bad.
Whilst we are here ive read loads of old threads and 5v at the pump plug keeps coming up. Some/most say you should have battery voltage at the pump but there is plenty of threads with people finding 5v at the fuel pump plug which we have. I ran out of time so couldnt fault find but i now have a diagram with wiring colours so will get this car started. I've not followed the diagram back to where the power comes from, just seen that it is linked from the injectors power. On a mighty/far superior turbo should i see 5v or battery voltage at the fuel pump plug? Currently got 5v and don't want to trace back if its right and problem is the pump side?
Cheers in advance.
By the way the car looks great and i cant believe Nigel painted it him self. The fecker has bought another white car with black bits which i find slightly disturbing but apparently its very "G" If you don't know what it means you aren't as down with the kids as i am YO!
Posted 06 April 2014 - 09:50 PM
It'll definitely be 12v (or whatever the alternator outputs) once the engine is up an running. The fuel pump relay might conceivably get a 5v signal from the ECU to energise the 12v high current side of the relay but don't know for sure.
Edited by techieboy, 06 April 2014 - 09:53 PM.
Posted 06 April 2014 - 09:55 PM
Cheers ill check my car voltage at the relay to compare but i'm not going to strip my car to check the voltage at the pump. Dont fancy taking the pump out of one of those ally tanks! (Again )
Posted 06 April 2014 - 09:57 PM
Fcuking miserable job that, or at least putting it back in is.
Posted 06 April 2014 - 10:02 PM
Fingers crossed we wont have to but the failing to start is defo down to fuel as we are getting nothing at the rail and even removed the flow side out of the pump to see if we got anything but sadly not. Funny thing is the 20A fuse was blown! We will sort it and report the fault.
Posted 07 April 2014 - 07:07 AM
Why not? I'd like to see a little more commitment here, George.but i'm not going to strip my car to check the voltage at the pump.
Tbh, watching someone else do it isn't that badFcuking miserable job that, or at least putting it back in is.
