Wiring Led Rear Lights
#141
Posted 14 November 2012 - 08:44 AM
#142
Posted 14 November 2012 - 09:17 AM
Well I want to do it a nice subtle dark grey but apparently that's not acceptable, needs to be some lairy, bright, in your face type of colour according to certain .org members....
A brighter color does bring out the extra new lines you put i there much better then a dark color.
Your car though.
#143
Posted 14 November 2012 - 09:36 AM
#144
Posted 14 November 2012 - 01:40 PM
Do you think these will work for the rears too?
Yep, I've done a test fit, should be ok. Interestingly (well, to me anyway) the Connect rear arches are a better starting point for both the front and back on the VX.
Difficult to accurately gauge how much wider a wheel will fit at this point, I've 8 inch rears and expect to add at least another inch and a half on top, an additional inch on the front too.
#145
Posted 14 November 2012 - 01:48 PM
#146
Posted 14 November 2012 - 02:30 PM
#147
Posted 14 November 2012 - 04:12 PM
Edited by SteveA, 14 November 2012 - 04:14 PM.
#148
Posted 14 November 2012 - 05:15 PM
#149
Posted 14 November 2012 - 05:45 PM
#150
Posted 14 November 2012 - 07:21 PM
#151
Posted 14 November 2012 - 07:35 PM
#152
Posted 14 November 2012 - 08:53 PM
how long do you reckon? Two weeks after Luke's VAG is finished?
See, I know what you're up to there Mike, you're trying to make me say the "D" word aren't you?
#153
Posted 14 November 2012 - 08:58 PM
...is that it for the bodywork?
Yes, absolutely, I've forgotten what it's like to drive the bloody thing.
Still,
You never know...you got an idea?
#154
Posted 14 November 2012 - 09:38 PM
Ebay for the secondhand arches Steve, 2002-06 Transit Connect rear, there are new ones at 30 ish but the seconhand ones are fine and go for around the 20 quid mark plus delivery.
I'll be fitting the rears at the weekend (if I can get the rear clam aligned properly) so I'll take some pics as I go along, but basically yes, bonded on after some judicious trimming. Temporary bolts through the clam hold them to shape whilst bonding.
There's no going back once you start though, it's not a job to do if you are precious about your bodywork!
I've already cut a set of the front louvres in so I'm fine with cutting the clam. I feel a winter project coming on
#155
Posted 15 November 2012 - 07:41 AM
#156
Posted 15 November 2012 - 07:42 AM
#157
Posted 15 November 2012 - 08:20 AM
It's looking great.
Looking forward to seeing it with a solid colour to see the lines properly
#158
Posted 16 November 2012 - 01:30 PM
#159
Posted 02 December 2012 - 04:25 AM
#160
Posted 22 December 2012 - 02:38 PM
Front wheel is a standard rear 17" x 8J with a 16mm spacer, could probably do with 5mm shaving off to pull it in a bit.
On the back is another rear, again with a 16mm spacer, plenty of room here for another inch and a half on the width.
Plan is to get the molds finished by the end of the Xmas break.
That's the plan anyway
