Lotus 4 Channel Abs - Group Buy
Posted 01 May 2012 - 07:58 PM
Posted 01 May 2012 - 08:30 PM
Posted 01 May 2012 - 09:38 PM
Posted 01 May 2012 - 09:39 PM
Edited by MrSimba, 01 May 2012 - 09:40 PM.
Posted 01 May 2012 - 09:44 PM
I've been looking for a decently priced second hand one for a while now. Rang round loads of places.
I asked about the above linked one, if he'd split & take an offer on just the ecu part when it was up well over a month ago at a higher price. He said no... It's still for sale!
I've since had a cut off switch fitted instead & so far pretty impressed with the improvement.
Cheers.
Does the ABS light come on with the cut off switch? I've been planning to take out the fuse if it gets too much of a problem but this obviously puts the light on.
Cheers,
Phil
Posted 01 May 2012 - 09:47 PM
Posted 01 May 2012 - 09:53 PM
Yes light is on
Cheers.
Cheers,
Phil
Posted 01 May 2012 - 09:54 PM
Cheers.
Cheers,
Phil
It does put the dash light on yes & I thought it might do my head in but it's not that noticeable after a few minutes. I have found some instructions for putting another switch in the instrument cluster wiring to switch the dash light off but guess that will involve removing the whole dash top so if that's the case I'll live with it for now.
Also think you'd want to disconnect the n/s wheel sensor if you want to try it before fitting a switch as I believe pulling the fuse will disable the speedo as well.
Cheers.
Posted 01 May 2012 - 10:00 PM
Posted 01 May 2012 - 10:07 PM
Is it only me that sees the irony of a 4-channel abs unit being advertised with a front end smashed Elise?
Posted 01 May 2012 - 10:21 PM
lol
Posted 01 May 2012 - 10:31 PM
can someone tell me what the implications of running 16/17 wheel setup are without changing the abs ecu? i.e., when does it affect things and how exactly?
I allready had the 16 wheels when i got my car, but ice mode was active on spirited braking on my car.
To a point it was totally spoiling my trackdays, and i had zero faith in the brakes.
The cut off switch was a godsent. Now also running the 4 channel but have not tested that.
Icemode is when you brake and nothing happens.
Edited by smiley, 01 May 2012 - 10:32 PM.
Posted 01 May 2012 - 10:37 PM
OK, thanks. so with the cutout, you just don't have abs??
Is there a tutorial to fitting the cutout on here anywhere?
Posted 01 May 2012 - 10:38 PM
Posted 01 May 2012 - 10:43 PM
Yes, when the signal on any of the wheels is disturbed, the system disables itself.
You can just unplug the abs sensor plug on either wheel, (other then left rear as that one is used by the speedo) as a test first.
Just ductape it to something, so the wheel does not schred it to pieces.
That way you can easily test if an abs disablement is the thing for you.
Once convinced, you can add a 2 pound switch (or buy a 600 pound 4 channel abs ecu):
http://www.vx220.org...146-abs-switch/
Edited by smiley, 01 May 2012 - 10:46 PM.
Posted 01 May 2012 - 10:44 PM
And, does this phenomenon only happen under heavy braking, or is it a constant issue?
Heavy breaking,
If you just use the car to drive to tesco and back, you may not notice.
Posted 01 May 2012 - 10:56 PM
Posted 02 May 2012 - 06:16 AM
Posted 02 May 2012 - 06:32 AM
