Lotus 4 Channel Abs - Group Buy
279 replies to this topic
#21 iVXT
iVXT
  • 680 posts
Posted 02 May 2012 - 06:51 AM
Sorry typo meant fit to NSF doh won't let me edit it now...
#22 JG
JG
  • 13,612 posts
Posted 02 May 2012 - 02:31 PM
Anyone fancy a group buy? I've got down to the following prices with Chris Neil (No dodgy uklotuscenter here) over £100 off list: for 3 units: £345+vat (£414) for 6 units: £325+vat (£390) :D
#23 Pazuzu
Pazuzu
  • 195 posts
Posted 02 May 2012 - 03:14 PM
I'm in at the 6 unit price :) (If that seems quiet tight then I apologize :) I've spent a fortune in the last few weeks and can barely justify the £390)
Edited by Pazuzu, 02 May 2012 - 03:18 PM.
#24 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 02 May 2012 - 03:24 PM
Do those prices include coding JG?
#25 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,515 posts
    "Yes, I built it"
Posted 02 May 2012 - 04:41 PM
I might even be tempted for the x6 option, depends on head count I guess...
#26 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 02 May 2012 - 04:56 PM
over £100 off list:
:D
I could also be in for the 6 unit price. Shall we start a list and see how many we get to - hopefully 6 or over...
1. JG
2. Graeme Lambert (if 6+)
3. Pazuzu (if 6+)
4.
5.
6.
#27 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 02 May 2012 - 05:14 PM
Any further discounts it you get more than six James? 10+? Or would it not be worth CN's while
#28 Bootdog
Bootdog
  • 556 posts
I'm on for this, I was only researching vacuum cannisters etc. last week. I'll be using it for wet trackdays, I'll hopefully never need it on wet roads if you get me ;-) 1. JG 2. Graeme Lambert (if 6+) 3. Pazuzu (if 6+) 4. Bootdog 5. 6.
#29 Ansk
Ansk
  • 475 posts
Posted 02 May 2012 - 06:09 PM
1. JG
3. Pazuzu (if 6+)
4. Bootdog
5. Ansk (if 6+)
6.
#30 Winstar
Winstar
  • 4,264 posts
Posted 02 May 2012 - 06:10 PM
over £100 off list:
:D
Will they activate them as well?
#31 Paulus H
Paulus H
  • 2,063 posts
Posted 02 May 2012 - 09:50 PM
You will not regret having one of these. Really good mod. Bear in mind if you get air in your ABS unit you'll have to swap the brain over to std VX and Tech2 the air out. Obviously air in the pipes and callipers can be bled out the normal way. Kind regards, Paul
#32 14500rpm
14500rpm
  • 381 posts
  • Interests:Boobs, Cars. Motorcycles.
Posted 02 May 2012 - 10:02 PM
I'm in for this.
1. JG
3. Pazuzu (if 6+)
4. Bootdog
5. Ansk (if 6+)
6. 14500rpm
Edited by 14500rpm, 02 May 2012 - 10:03 PM.
#33 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 03 May 2012 - 06:32 AM
Running on 17 16 combo it isnt really any better at all, with 888's. If your beaking and hit the slightest bump, ice mode happens. Martin s
#34 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 03 May 2012 - 08:02 AM
Martin s
I thought this was the fix for ice mode. Have you had it then Martin with the replacement unit?
#35 MrSimba
MrSimba
  • 5,197 posts
Posted 03 May 2012 - 08:10 AM
On 16/17 with R1R after fitting the Nitrons the 'ice mode' was almost a permanent feature of the car! Since the 4 channel units been fitted its not happened once :) This includeds driving absolutely 'flat out' on broken Tarmac on a Walshy day, Andy even commented how much better the ABS was than the 'shocking' ( his words not mine! ) standard ABS!
#36 JG
JG
  • 13,612 posts
Posted 03 May 2012 - 08:13 AM
If we can get to 10 i reckon there is a tiny bit more room :D
#37 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 03 May 2012 - 08:16 AM
Well we've got six so far, in a relatively short time.
Lets go for ten...
G
#38 CocoPops
CocoPops
  • 17,181 posts
Posted 03 May 2012 - 08:17 AM
1. JG
3. Pazuzu (if 6+)
4. Bootdog
5. Ansk (if 6+)
6. 14500rpm
7. CocoPops
#39 techieboy
Posted 03 May 2012 - 08:19 AM
That's what finally convinced me. Driving somebodies 111R back to back with my car on a Walshy day. Difference was night and day.
Like you, never had a hint of ice mode on road or track, other than when I've been a little keen on the brakes pulling into a gravel car park (and my A4 quattro would barf at that as well).
#40 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 03 May 2012 - 08:25 AM
Am I right in thinking that you both run 16/17 combo as well?
Just to convince some of the possible doubters out there... (i'll be sticking with 17/17)
G
