4 Channel Abs Part Number And Installation Guide
A120J6004S S108196012
3 replies to this topic
#1 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 06 May 2012 - 07:07 AM
It's not a hard thing to change over but there does seem to be some confusion over part numbers.
The Lotus 4 channel ABS actuator is part number 2 on the below diagram.
Item Qty Part Number Description Notes
01 1 A120J6000F ABS Control Module
02 1 A120J6004S ECU Kit, ABS actuator
03 1 A116M0091S HCU Kit, ABS actuator
In reality this is what the part looks like
Additionally the part number (found on the bottom of the unit) is NOT the reference as above, it is instead S108196012
New ABS unit
Fitting the unit was pretty simple. Remove the connector from the unit by sliding the clip sideways
Undo the four torx head screws and remove the computer unit from the hydraulic unit.
After that simply install the new computer with new rubber seals by reversing the procedure
here's the original 2 channel unit part number
#2 iVXT
iVXT
  • 680 posts
Posted 06 May 2012 - 11:01 AM
Good guide & pics. Sure this will clear up any confusion about part numbers etc people have. Cheers.
#3 Fredrik andersson
Fredrik andersson
  • 3 posts
Posted 15 May 2019 - 02:14 PM
Ive recently head that some ''4 channel'' ab systems on ebay might actually be the original 2 channel with a sticker identical to the 4 channel = you think your paying for a 4 channel but i actually is the same rubbish 2 channel you already had.
does anyone know how to tell the diffrence between the systems appart from what the sticker says?
#4 vocky
Posted 15 May 2019 - 02:55 PM
they are the same unit, but with different software, so without testing it on a car it's not going to be very easy to tell them apart.
Once fitted to a vx220 the 2 channel abs ECU can be seen on some vauxhall diagnostic software, but the 4 channel Lotus item needs specific Lotus diagnostic software
