I have for sale my PWR Barrel Chargecooler Setup which was originally fitted to my VW T25 van . Since i have decided to go Subaru NA power for the heart of my van this Chargecooler set up is now surplus to requirements and every penny towards installing this scooby will be well and truly needed.
It truly is a very good chargecooler and was always cold to the touch even when running 18PSI of boost !
The kit consists of:
26" Twin Pass pre radiator http://www.chargecoo...products_id=183
4x6" PWR Barrel http://www.chargecoo...products_id=190
Bosch 12V pump http://www.chargecoo...products_id=184
Pace Products Swirl tank - this really helps with bleeding the system which can be a right royal pain in the arse on other systems
Connector block
5m of piping and several 90 deg fixings + 2 130 degree silicone bends
If you want i will throw in the Mounting kit for pump and chargecooler core that i fabricated them for a quick install and do the job quite well.
I spent well over £600 and i am asking just £400
Im based in northampton and you can contact me by email or phone.
Herukano@gmail.com
07715496954
