Tullet Cat Failure, How Many?
Posted 19 May 2012 - 03:13 PM
Posted 19 May 2012 - 03:37 PM
Posted 19 May 2012 - 03:39 PM
Posted 19 May 2012 - 04:00 PM
Posted 19 May 2012 - 04:57 PM
Posted 19 May 2012 - 06:09 PM
Posted 19 May 2012 - 06:21 PM
Posted 20 May 2012 - 10:20 AM
Posted 20 May 2012 - 10:27 AM
Posted 20 May 2012 - 04:18 PM
Are the fails from Supercharged cars only - is it worth annotating the list with induction type? From quick look at the above, they all look like SC cars...? Do they run hotter, hence accelerate the breakdown?
They run far too rich and then kill the cat.
Posted 20 May 2012 - 05:32 PM
On that basis, a fairly unmolested NA should be ok?
Edited by Big_bazza99, 20 May 2012 - 05:33 PM.
Posted 20 May 2012 - 05:54 PM
Posted 20 May 2012 - 06:22 PM
Errr, no. I've never managed to kill a cat, no even when my engine was over fuelling enough to give me bore wash and about 15mpg on a cruise. They've just got a sh*t substrate that isn't attached firmly enough within the casing and come loose. Then when it's off the car you can feel the substrate move backwards and forwards 5mm when you tip it one way or the other.
Posted 20 May 2012 - 08:12 PM
I beleive its them running retarded which in turn gives a high EGT. This melts the braze on the substrate meaning it moves / cools / sets / moves etc until all the braze is gone. A staked cat wont move so you tend not to loose the braze. My tullet cat has done less than 500 miles (switched it out) and is fooked. Bag of crap system, has never done what they claimed.
Posted 20 May 2012 - 08:22 PM
No idea what the state of play is with my stage 3 and the blower cams but, for my original high compression stage 2, Courtenay certainly had to retard the ignition. Once I'd got the uprated rods and lower compression pistons fitted, the ignition was advanced back to it's standard timing during all of the part throttle mapping.
Posted 21 May 2012 - 01:22 AM
Posted 21 May 2012 - 07:09 AM
Posted 21 May 2012 - 07:33 AM
Posted 21 May 2012 - 07:39 AM
Posted 21 May 2012 - 07:41 AM
