2 Questions On My Supercharger Install
Egr Supercharger lambda
5 replies to this topic
#1 jhinchy
jhinchy
  • 98 posts
Posted 11 June 2012 - 11:09 PM
Ive made a start on my SC conversion on my speedster. Is it necessary to remove the EGR and fit a cheater? Or can it just be blocked and left plugged in? I also have a trouble code for the lambda sensor, p0121 (iirc). I've cleared it a few times but it always comes back on. The car has a piper exhaust fitted. Will I need to get this sorted before I fit the charger?
#2 Nelly Vx
Nelly Vx
    3/3 Of a Queen
  • 5,928 posts
Posted 11 June 2012 - 11:13 PM
You can fit the blanking plate and fit the egr back with one bolt and plug it back in , your exhaust fault is probably a faulty sensor or damaged wiring , that won't stop your SC build :-)
#3 Rally
Rally
  • 650 posts
Posted 11 June 2012 - 11:14 PM
Nelly beat me to it!
You could avoid buying a cheater by detaching the EGR valve but leaving it plugged in but you may as well spend £10 on the cheater and just chuck it!
Edited by Rally, 11 June 2012 - 11:16 PM.
#4 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 12 June 2012 - 06:45 AM
Get the cheater and blanking plate, think of that extra weight slowing you down.
#5 jhinchy
jhinchy
  • 98 posts
Posted 12 June 2012 - 09:18 PM
I removed the old NA inlet manifold tonight, I understand now how the EGR works, and why it needs to be blocked. Il order a blanking plate in work for it. I had a look on z22se.net, but the cheaters are out of stock, is there anywhere else to get one?
#6 smiley
Posted 12 June 2012 - 09:34 PM
You can also extend the egr from the blanking plate, untill you get your hands on a cheater.
(will technically work, but no longer functional)
Also tagged with one or more of these keywords: Egr, Supercharger, lambda
