So its not a VX but thought I'd stick it here as I know a lot of you are thrill seekers
So I bought this car about 3 years ago. I actually traded my Exige in for it, and its effectively sat in my garage ever since. I've done probably about 300 miles in it since I purchased it, and the car in total has covered only a few thousand. There was only ever 11 made and this was the first to ever be built. Its totally road legal with a valid MOT and Tax (currently expired).
The car has a tuned R1 engine in it running approx 180hp. The car weighs in at around 320kg so as you can imagine, this thing is insane for want of a better word. 0-60 is around 3 seconds and it'll pull up to around 140mph but in all seriousness I actually don't have the balls to go that far. I've had it up to around 125mph on a track and that was scary enough for me. I never get to drive it any more and as I'm getting older I simply scare myself with things like this now hah.
I paid 14995 for the car and I did actually over pay for it so I'm asking around 10-12k. I'm open to a bit of negotiation.
The car had a full service by pure lotus last year as I was going to take it to Spa for the F1 but then had to pull out of the trip. MOT will be due in a few months, but there isn't really anything that it can fail on. Only stipulation is that there needs to be a valid front number plate, so stick one on, take it off once done.
The car is in good condition, but needs a decent clean (I'll get that done) as its just been sat doing nothing.
The car is easy to drive. It has your normal setup, clutch, brake, go faster pedal. The gear box is obviously sequential and is done on via paddles on the steering wheel. The noise this thing makes is truely insane and the only way to really appreciate it is to drive it. Its actually a really comfortable drive, which I know is hard to believe, but for some reason even on bad roads it isn't anywhere near as harsh as my VX is.
The seat is NON ADJUSTABLE. You can adjust it, but you need to unbolt it and bolt it back in. I'm 6ft 1 and its just about fine, any taller and you would need to move it back.
Not sure what else to say about it really, so if you have any questions let me know
These pictures were taken end of last year when I stil had the VX, which is obviously now sold!
Just to add, I'm happy to take a part ex against it.
