Kumho V70
Posted 30 June 2012 - 10:04 PM
Posted 30 June 2012 - 10:13 PM
Posted 30 June 2012 - 10:15 PM
Vehicle Weight<1100kg
Minimum Cold
Front 24 psi
Rear 22 psi
Minimum Hot F & R 34 psi
Use of Dry Air or Nitrogen
The use of dry air or nitrogen will reduce COLD to HOT pressure increase by between 50%
and 75% and COLD tyre pressures should be increase accordingly.
Please note. The FSport Event Support truck is fitted with membrane air filters which produces
95% dry air. Tyres filled with air from this source will not generate as much pressure increase
between COLD and HOT conditions as would tyres filled with normal compressed air.
Tyre Temperatures
Tyre Temperature Range 80’C- 120’C (160’F – 240’F)
Edited by chris_uk, 30 June 2012 - 10:18 PM.
Posted 30 June 2012 - 10:19 PM
Posted 30 June 2012 - 10:22 PM
Posted 30 June 2012 - 10:23 PM
i imagine it would be slightly tricky on your own tho.
34psi hot!!!!! Surely not
Yoko reccomend A048's at 33-36 degrees for optimum temp.
Edited by chris_uk, 30 June 2012 - 10:25 PM.
Posted 30 June 2012 - 10:27 PM
tyre pressures mean nothing on their own, you want to get a pyrometer and start measuring temps and then altering your tyre pressure to get the temp you want.
I agree that temps are the most accurate way but that's for perfectly dialing in to a specific track on race day. Temps at edges, and middle etc, but as a rule pressures are more than adaquate for track days
Posted 30 June 2012 - 10:29 PM
Posted 30 June 2012 - 10:31 PM
Edited by chris_uk, 30 June 2012 - 10:33 PM.
Posted 30 June 2012 - 11:10 PM
Posted 01 July 2012 - 05:54 AM
Posted 01 July 2012 - 06:51 AM
Posted 01 July 2012 - 08:01 AM
Posted 01 July 2012 - 08:14 AM
Posted 01 July 2012 - 08:17 AM
i have put up a 7% discount code for these in the premium members forum , should be worth about £50 on the V70
Yeah I saw that Steve good shout, does it cover the larger 'DTC' type sizes too...? thought is was just the standard sizes?
Posted 01 July 2012 - 10:00 AM
