Posted 02 July 2012 - 04:31 PM
Posted 02 July 2012 - 04:45 PM
Posted 02 July 2012 - 05:11 PM
Posted 02 July 2012 - 06:04 PM
Posted 02 July 2012 - 06:24 PM
Posted 02 July 2012 - 06:30 PM
1 x Mount V Base with 1" Ball and Straps (RAM-B-108B)
1 x Short Double Socket Arm for 1" Ball (RAM-B-201-A)
1 x 1" Ball Camera Adapter with 1/4"-20 Threaded Stud (RAM-B-237)
I just leave it permanently mounted as it's so unobtrusive and just screw the camera onto the thread as needed. I had Drift and it worked perfectly on there as well.
Posted 02 July 2012 - 07:02 PM
Posted 02 July 2012 - 08:37 PM
I've been through Manfrotto stuff and even managed to break it, it's also way too bulky for use in a car, unless you specifically need one of their clamps or suction mounts.
That seams a simple and eloquent solution. The Manfretto gear indeed seems well made but far too big to fit between the seats. Plus you said it worked well with your Drift.
Edited by techieboy, 04 July 2012 - 09:47 PM.
Posted 02 July 2012 - 09:07 PM
Yep, it's absolutely rock solid and really low profile. The Drift Stealth I had for a while worked fine with it as it has a normal 1/4" tripod mount on the base. It won't work with the mount in that configuration (well it would with the rotatable lens but I think it would be too low a viewpoint) but it's just a case of rotating the rollbar mount so that it's mounted above the bar and not below. As there are two "balls" in the mount in that guise, you get a huge amount of adjustment to get the perfect positioning. Well worth it.
Posted 02 July 2012 - 09:32 PM
Posted 02 July 2012 - 09:40 PM
I've had an Ultraclamp for a few years now
Broke the threaded section on one of those too and it left it behind in the camera.
Posted 02 July 2012 - 10:08 PM
Posted 02 July 2012 - 10:11 PM
Posted 04 July 2012 - 08:30 PM
Now working on the original sliding clip that came with the Drift, and mounting it on the RAM ball, so that the mount stays in the same place when removing and mounting the camera.
Just need some National action !!
Posted 04 July 2012 - 08:35 PM
Posted 04 July 2012 - 08:40 PM
Posted 04 July 2012 - 09:36 PM
cool
As you said, 'Jubilee clips can work wonders on tube'
Posted 05 July 2012 - 06:56 AM
Also tagged with one or more of these keywords: Harness bar
The Market Place →
Car Parts Wanted →
Harness BarStarted by apple2000 , 02 Jan 2020 ![]() |
General Discussion →
VX220 Discussion →
Jon BettsStarted by D-DAWG83 , 09 Jul 2015 ![]() |
The Market Place →
Car Parts For Sale →
Parts For SaleStarted by wantsum , 03 Aug 2013 ![]() |
The Market Place →
Various Parts For Sale - Jonnyboy Hardtop, Soft Top, Lights, EtcStarted by Gazza75 , 20 Feb 2012 ![]() |
