Fuel System Overhaul
#121
Posted 14 July 2012 - 08:12 PM
#122
Posted 14 July 2012 - 10:55 PM
http://www.eaavideo....x?v=46881475001
this gives you an idea of how to fit them.
Perfect cheers mate! Looks simple enough.
#123
Posted 14 July 2012 - 11:02 PM
Pump Fittings =
1 x AN -6 (-6AN JIC AN-06) Quick Connect 5/16" Female Fuel Line / Rail Adapter Link £14.99
1 x AN -6 (-6AN JIC AN-06) Quick Connect 3/8" Female Fuel Line / Rail Adapter Link £14.99
2x AN -6 (AN6 AN 06) 150 Degree Fast Flow Hose Fitting Link £20.98
Integrated Swirl Pot = £228 (tank), £129 (pump)
1 x Pump outlet AN -6 (6AN AN6) Bosch 044 / 910 Fuel Pump Outlet Check Valve In Red Link £26.99
3 x XRP Aeroquip Hose Fitting,Goodridge Type -6x-6 male Link £16.50
Fuel Rail Fittings =
1 x GM 2.2L 2.4L Ecotec fuel rail adapter adapters fitting Link £28.94
2 x AN -6 (AN6) 90 Degree Teflon Hose Fitting Aeroquip Type Link £24.98
Filter Fittings =
Hose A Fittings =
Hose B Fittings =
Hose C Fittings =
Hose D Fittings =
Hose E Fittings =
#124
Posted 15 July 2012 - 09:15 AM
30 Micron and 100 micron, which is which...? Can I just use two 30 micron filters...?
http://www.ebay.co.u...=item256fdb4f4e
#125
Posted 15 July 2012 - 10:41 AM
I went for this one after looking around a bit and recomendation from Rally
http://www.ebay.co.u...984.m1497.l2648
#126
Posted 15 July 2012 - 11:44 AM
My view is that those are too small.
Ouch!!! I guess I need two of those!!
#127
Posted 15 July 2012 - 11:51 AM
#128
Posted 15 July 2012 - 03:56 PM
#129
Posted 15 July 2012 - 04:04 PM
#130
Posted 15 July 2012 - 06:50 PM
You have to get a filter just before the high pressure pump, especially with a Bosch 044 which can be very sensitive to this.
As my pump is integrated in the swirl pot would you recommend I break into fuel line A with a 100 micron filter, then another filter directly after the pump (as shown)?
Also guys, the electrical connection is the next thing I have to deal with.....
Where would I pick up the supply for the high pressure pump...? Slave it off the existing pump controller...? There's talk of this needing a high current supply so is this sufficient or should I run a fused line from the battery and come up with some form of relay to control it...?
#131
Posted 15 July 2012 - 06:53 PM
#132
Posted 15 July 2012 - 06:54 PM
#133
Posted 16 July 2012 - 08:03 AM
Keep in mind when selecting a new/alternative fuel filter: OEM fuel filters are usually 8 micron or better.
#134
Posted 16 July 2012 - 08:23 AM
#135
Posted 17 July 2012 - 12:19 PM
thats why i selected the 8micron posted above
Yeah sure the 8 micron will be after the second pump to protect the engine, I am talking about the first filter after the first pump to protect the second pump
Annnyway - - - The Fuel rail adapters. Do we have a UK source for these or do they have to be ordered from the states..?
#136
Posted 17 July 2012 - 12:20 PM
#137
Posted 17 July 2012 - 12:35 PM
From the States off eBay. Not the quickest of delivery I have to be honest.
Cheers Mike, that's a bugger then!! Got them on order now. You had a problem with the thread depths no...?
#138
Posted 17 July 2012 - 12:43 PM
#139
Posted 17 July 2012 - 12:45 PM
I'm making a new set to fit direct to the rail.
They may not be done in time for you though Jimmy. You can always upgrade later.
I had the same problem as Mike, took half a mm off the return adaptor and its now fine.
Yup, that was the issue I had as well.
Damn this thread, I need to fit my bladder tank now.
#140
Posted 17 July 2012 - 03:24 PM
That's not baffled! Why not sell me the bladder tank and spend the money on tyres
