Fitting Spacers To The Tat Diffuser
Posted 18 July 2012 - 05:47 PM
Posted 18 July 2012 - 05:50 PM
There are 7 fixings and all 7 will require spacers - just use a longer bolt when you re-fit with the spacer.
With the sides just drill the base of the trim into the clam and use a black headed bolt to secure it, don't try to fix to diffuser as when spaced it won't reach
Edited by MrSimba, 18 July 2012 - 05:59 PM.
Posted 18 July 2012 - 06:43 PM
Posted 18 July 2012 - 07:03 PM
Posted 18 July 2012 - 08:04 PM
Posted 18 July 2012 - 08:37 PM
'JG', on 18 Jul 2012 - 7:03 PM, said:
I don't fit the rear fittings, they don't really add to the rigidity and they make removing the diffuser a much longer task. so i only fit the 5 on the rear clam.
If you do fit the rear 2 they will need to be thicker than the 5.
Thanks for the info il try and sus it out tomorrow
Posted 18 July 2012 - 08:39 PM
Edited by MrSimba, 18 July 2012 - 08:41 PM.
Posted 18 July 2012 - 08:43 PM
Posted 18 July 2012 - 08:51 PM
Posted 18 July 2012 - 08:54 PM
Posted 18 July 2012 - 08:55 PM
'Ebo100', on 18 Jul 2012 - 8:51 PM, said:
What am I missing here, why does there need to be spacers?
My TAT screws to the chassis in two places and then there are several screws into the clam. Is this an anti rattle solution?
LOL! Aesthetics friend, Aesthetics
No more performance or 'anti rattle' just looks
Edited by MrSimba, 18 July 2012 - 08:56 PM.
Posted 18 July 2012 - 08:59 PM
Posted 18 July 2012 - 09:32 PM
'MrSimba', on 18 Jul 2012 - 8:39 PM, said:
I found it a 'must' that when you re-fit the diffuser to put some 'liquid metal / tigerseal' ect on the bars that hold the 'C' clips to to bond them to the clam, then when you come to re-fit in future the bolts just push in rather than trying to hold the bars through the wheel arch!
All my spacers are 2 x 7.5mm except the centre one under the exhaust which is 3 x 7.5mm - the diffuser sits perfectly straight in line with the ground then
Thanks for that
Posted 19 July 2012 - 06:19 AM
Posted 19 July 2012 - 08:07 AM
Posted 19 July 2012 - 08:21 AM
