Larger Intercooler V's Charge Cooler
#81
Posted 17 June 2013 - 09:56 PM
#82
Posted 18 June 2013 - 05:41 AM
#85
Posted 18 June 2013 - 08:29 AM
I used a obd2 Bluetooth via a HTC running Torque Pro I don't think my car boosts to 30psi... As never seen anything over 25psi on the gauge in the cockpitsorry Mark, was that torque you used to log the boost TMAP sensor as that usually doesn't work , so would be handy to know
I've been a bit slow to test Torque app on the VX, been doing lots of stuff on the Boxster with it. However yes I can confirm Torque (free version) can read the TMAP sensor, and therefore boost and charge temperature as seen after the Charge cooler/ Intercooler. It cannot read the barometric sensor though. Also so far no cylinder1-4 knock sensor degrees adjustment.
#86
Posted 18 June 2013 - 09:40 AM
Maybe something like this
http://www.ebay.co.u...=item3a8156efb5
That's what I been looking at, the question is will it be effective ?
#87
Posted 18 June 2013 - 12:40 PM
Cant see why it wouldn't work.
Its cheap enough just to order and have a play..
From reading up it lowers temps by about 10c.
#88
Posted 18 June 2013 - 12:42 PM
Ford use an IC spraybar on the escos rally cars. They also run some strange CC/IC hybrid system
#89
Posted 18 June 2013 - 12:55 PM
The wiring side always screws me over on stuff like this. It's beyond me.
#90
Posted 18 June 2013 - 01:23 PM
Huh? That's a totally dumbfuckski kit by the look of it. Just a manual switch, so it's either spraying or not spraying. Not like it needs a PWM output from the ECU or some kind of tie in to the throttle pedal and temp sensors. It's so straightforward you could stick a lighter plug on the end of the two wires and run it from the cigarette lighter socket. It's literally a windscreen washer kit with (hopefully) a pair of fine spray heads.
#91
Posted 18 June 2013 - 01:24 PM
#92
Posted 18 June 2013 - 01:34 PM
I hear what you're saying and admit myself it should be child's play but car + electrics = mind block for me, might be more fear as house electrics I'm fine with.Huh? That's a totally dumbfuckski kit by the look of it. Just a manual switch, so it's either spraying or not spraying. Not like it needs a PWM output from the ECU or some kind of tie in to the throttle pedal and temp sensors. It's so straightforward you could stick a lighter plug on the end of the two wires and run it from the cigarette lighter socket. It's literally a windscreen washer kit with (hopefully) a pair of fine spray heads.The wiring side always screws me over on stuff like this. It's beyond me.
#93
Posted 18 June 2013 - 01:48 PM
I'm the reverse. Won't touch anything more complicated than a plug when it comes to domestic electrics. Every time I open a socket or light fitting to replace it, I can guarantee there's at least 3 times more cables in there, than a diagram with the replacement suggests should be there.
Happy to pull a car loom apart though.
#94
Posted 18 June 2013 - 01:52 PM
#95
Posted 18 June 2013 - 02:07 PM
Doesn't this go back to the first few posts, re blowing on your finger, the suck it, the blow again (something like that)...
(if its not on the first few posts, then Ive read it somewhere, by JT)
#96
Posted 18 June 2013 - 02:09 PM
It was, correct.Doesn't this go back to the first few posts, re blowing on your finger, the suck it, the blow again (something like that)...
#97
Posted 18 June 2013 - 02:54 PM
This is in the realm of consumable intercoolers. Some drag cars run with intercoolers in a bucket of dry ice. That gets temps down but obviously doesn't last that long! Strkes me as a bit of a pain as its one more thing to fill up. (Lazy, me??)
#98
Posted 18 June 2013 - 02:58 PM
I agree with you.This is in the realm of consumable intercoolers. Some drag cars run with intercoolers in a bucket of dry ice. That gets temps down but obviously doesn't last that long! Strkes me as a bit of a pain as its one more thing to fill up. (Lazy, me??)
#99
Posted 18 June 2013 - 03:12 PM
#100
Posted 18 June 2013 - 03:22 PM
Send me the loom and the switch and I'll extend it and stick 'em together with a cigarette lighter plug , for true plug and play.
