Vx220 V.2 Heater
165 replies to this topic
#1 fezzasus
Posted 02 August 2012 - 05:29 PM
VX220 V.2 Heater
Specifications:
  • 660 cubic meters of air an hour
  • Retains original three fan speeds, 50 W resistors to prevent resistors burning out
  • Galvanised, black powder coated enclosure
  • Stainless steel fixings
  • Electronic heater control (no more stiff/stuck or broken cables)
  • Radiator tested to 2 bar pressure
  • Rubber grommets to isolate vibrations from fan
  • Mesh to prevent debris ingress
Price:
£320 + £12 shipping
Availability:
From the 23rd August
#2 fezzasus
Posted 02 August 2012 - 05:35 PM
List
I am aware this heater has changed significantly since the group buy first started; the unit and the resulting price are different, and the time frame has been dragged out much longer than I would like. Please update the list if you are no longer interested in a unit, and accept my apologies for the changing specifications.
1. Techieboy - V1 unit supplied, V2 will be made available
2. DuncanP - V1 unit supplied, V2 will be made available
3. TIP - V1 unit supplied, V2 will be made available
4. deltadeano - V1 unit supplied, V2 will be made available
5. Bargi
6. Tom - V1 unit supplied, V2 will be made available
7. robin - V1 unit supplied, V2 will be made available
8. ChrisS1 - V1 unit supplied, V2 will be made available
9. Ambrose - in progress, V2 will be made available
10. JG
11. VXed - V1 unit supplied, V2 will be made available
12. Ansk
13. Snotvomit
14. PaulCP
15. dumfunk (fitting required)
16. Graeme Lambert (MK fitting)
17. Worker (can collect from Oxford)
18. Zuber - Would be interested in fitting
19. Andrew Partridge (before end March)
20. ArticMonkey
21. hughcam
22. mstambach01 (MK fitting)
23. adH
24. T VXT (dont mind waiting until April/May or MK fitting day)
25. SteveA
26. Way-Aye-Pete (end of the summer is fine for me)
27. Kipper
28. The Fat Man.
29. Lou_m
30. elwill
31. Hark
32. CocoPops
33. (if suitable to LHD - Speedster) ginek
34. andywilson
35. Andy_sx
36. Asheey
37. TazN
38. Tink
39. Blueboy69 (MK Fitting)
40. jhinchy
41. Coates1947
42. Martin s (MK fitting if poss)
43. VX Boyd (MK fitting)
44. John Boy
45. Jaz Woodward
46. Ian Roberts
47. D4nnyk
48. rickyzero
49. cressey
50. YorB (with fitting, & as per PMs - black piping, please)
51. AMOSS
52. Silent Steve (with fitting, anywhere but Milton Keynes)
53. CT
54. neilchills (with MK fitting)
55. Kev S
56. Stigg10 (with MK fitting)
57. Chubbychiper
58. V220DR
59. Pazuzu
60. Dw1 (with MK fitting)
61. L0rdMike (with MK fitting)
62. Leevx220 (with MK fitting )
63. D3YMO
64. Rosssco
65. oblomov (whenever)
66. vocky (can collect from Oxford)
67. D-Dub (filter + fitting)
68. Nickb777
69. Gingerjon
70. M8VXL
71. Wick (w/filter + possible fitting depending on how competent I'm feeling nearer the time)
72. 2-20 (LHD)
73. T. Spark (filter + fitting)
74. Darcini
75. NickP (filter + possible fitting)
76. 2GOOD (filter + possible fitting)
77. Davemate
78. Marco
#3 smiley
Posted 02 August 2012 - 09:22 PM
"Electronic heater control" Where is/should this be mounted? Any pictures of this, and/or a v2 unit built into a vx? Are the units speedster compatible?
#4 fezzasus
Posted 02 August 2012 - 09:49 PM
It's mounted to the underside of the bracket
and uses a cable running into the cabin replacing the metal bike cable design of the original heater unit.
I have a few build pictures but they're on other computers, i will update later
As for speedster compatibility, I think so, I can mount the unit in place of my battery as a quick check, but I will need a willing test mule to confirm this.
#5 d4nnyk
d4nnyk
  • 769 posts
Posted 03 August 2012 - 08:28 AM
5. Bargi
10. JG
12. Ansk
13. Snotvomit
14. PaulCP
20. ArticMonkey
21. hughcam
23. adH
25. SteveA
27. Kipper
28. The Fat Man.
29. Lou_m
30. elwill
31. Hark
32. CocoPops
34. andywilson
35. Andy_sx
36. Asheey
37. TazN
38. Tink
40. jhinchy
41. Coates1947
44. John Boy
45. Jaz Woodward
46. Ian Roberts
47. D4nnyk (Sorry I'm out, do to price rise - only use the car at weekends)
48. rickyzero
49. cressey
51. AMOSS
53. CT
55. Kev S
57. Chubbychiper
58. V220DR
59. Pazuzu
63. D3YMO
64. Rosssco
68. Nickb777
69. Gingerjon
70. M8VXL
72. 2-20 (LHD)
74. Darcini
77. Davemate
78. Marco
#6 Pazuzu
Pazuzu
  • 195 posts
Posted 03 August 2012 - 08:59 AM
5. Bargi
10. JG
12. Ansk
13. Snotvomit
14. PaulCP
20. ArticMonkey
21. hughcam
23. adH
25. SteveA
27. Kipper
28. The Fat Man.
29. Lou_m
30. elwill
31. Hark
32. CocoPops
34. andywilson
35. Andy_sx
36. Asheey
37. TazN
38. Tink
40. jhinchy
41. Coates1947
44. John Boy
45. Jaz Woodward
46. Ian Roberts
48. rickyzero
49. cressey
51. AMOSS
53. CT
55. Kev S
57. Chubbychiper
58. V220DR
59. Pazuzu - No VX at the moment so dropping out for the time being :(
63. D3YMO
64. Rosssco
68. Nickb777
69. Gingerjon
70. M8VXL
72. 2-20 (LHD)
74. Darcini
77. Davemate
78. Marco
#7 CocoPops
CocoPops
  • 17,182 posts
Posted 03 August 2012 - 09:04 AM
Are those electronics waterproof there? Do you have a solution for covering them up?
#8 fezzasus
Posted 03 August 2012 - 09:34 AM
It's spray resistant, probably wouldn't cope with complete dunking but then I doubt the motor would either.
It's mounted on the underside of the enclosure when fitted, so forms part of a five sided box with the chassis making up four of the sides and the heater bracket making up the other side. In practice it's exposed to very little.
Example of the blower and bracket fitted, the electronics are mounted on the bracket facing towards the floor. Th radiator assembly then bolts directly on to the fan outlet - this installation approach means that larger parts can be used than if the unit stays as one piece (larger parts = more airflow at a lower noise level, and a deeper radiator for better heat transfer)
#9 spuk87
spuk87
    Ex-owner
  • 3,624 posts
Posted 03 August 2012 - 09:40 AM
Do I spy a Fiesta/Ka/Transit heater valve there?
#10 fezzasus
Posted 03 August 2012 - 09:50 AM
Yes. It's the only electronic valve commonly available - the majority of non-automotive specific solenoids are either massive or don't have the flow requirements (typically have a 1 mm opening). Most cars use vacuum operated valves but I was loathe to tap into the servo vacuum hose or try to run a second one.
#11 JG
JG
  • 13,612 posts
Posted 03 August 2012 - 10:19 AM
Very neat. Any need to drill holes in the car?
#12 fezzasus
Posted 03 August 2012 - 10:25 AM
Very neat.
None at all. It's designed as a bolt in unit using existing mounting points (admittedly more of them - four in total). The potentiometer that replaces the cable heater controller first directly in place and uses the same grommet to exit the dash and the rubber pipes that feed the heater unit stay unaltered.
Davemate and andywilson bought the two pre-production units (made with sample parts rather than the batch I expect on the 23rd), so hopefully you will start to hear something more impartial over the next week or two.
#13 MWS
MWS
  • 1,229 posts
    Cars - VX220s
    Basketball - Miami Heat
Posted 03 August 2012 - 01:04 PM
Is this a one chance deal or could this be purchased at a later date? Cheers
#14 andywilson
andywilson
  • 547 posts
Posted 03 August 2012 - 01:32 PM
as already said i've bought the one using sample parts once i've got it fitted (should be in the next week or two) i'll give feedback
#15 fezzasus
Posted 03 August 2012 - 01:36 PM
Cheers
I have 100 blowers on order so will be able to provide that number of complete units. If or once I have reached 100 I will need a certain level of interest before I order a second batch of blowers.
#16 John Boy
John Boy
  • 222 posts
Posted 09 August 2012 - 12:35 PM
Looks like a very nicely developed bit of kit, but funds are tight now, so:
5. Bargi
10. JG
12. Ansk
13. Snotvomit
14. PaulCP
20. ArticMonkey
21. hughcam
23. adH
25. SteveA
27. Kipper
28. The Fat Man.
29. Lou_m
30. elwill
31. Hark
32. CocoPops
34. andywilson
35. Andy_sx
36. Asheey
37. TazN
38. Tink
40. jhinchy
41. Coates1947
44. John Boy - (Too rich for me right now. Looks quality, but money put topwards a new coat :happy: )
45. Jaz Woodward
46. Ian Roberts
48. rickyzero
49. cressey
51. AMOSS
53. CT
55. Kev S
57. Chubbychiper
58. V220DR
63. D3YMO
64. Rosssco
68. Nickb777
69. Gingerjon
70. M8VXL
72. 2-20 (LHD)
74. Darcini
77. Davemate
78. Marco
#17 Zuber
Zuber
  • 1,429 posts
  • Interests:Finding a way to motivate myself to get fit. Anything Interesting.
Posted 10 August 2012 - 10:18 AM
My heating isn't actually that bad (or maybe it's summer and it just feels that way). So the new Deluxe version is a bit too much to justify. I'm going to do some insulating and and play with a couple of budget ideas I've got for now and the money goes to SC fund...
Impressive bit of kit though...
5. Bargi
10. JG
12. Ansk
13. Snotvomit
14. PaulCP
20. ArticMonkey
21. hughcam
23. adH
25. SteveA
27. Kipper
28. The Fat Man.
29. Lou_m
30. elwill
31. Hark
32. CocoPops
34. andywilson
35. Andy_sx
36. Asheey
37. TazN
38. Tink
40. jhinchy
41. Coates1947
45. Jaz Woodward
46. Ian Roberts
48. rickyzero
49. cressey
51. AMOSS
53. CT
55. Kev S
57. Chubbychiper
58. V220DR
63. D3YMO
64. Rosssco
68. Nickb777
69. Gingerjon
70. M8VXL
72. 2-20 (LHD)
74. Darcini
77. Davemate
78. Marco
#18 cressey
cressey
  • 966 posts
Posted 18 August 2012 - 09:59 AM
I'm still in. I use mine as a daily and remember what a nightmare the winter season was last year; countless occasions of scraping ice off the inside of the screen. I see you've got them available as of 23rd August but I'm quite far down the list. Any estimation on when I could expect to see one? Cheers again for doing this.
#19 fezzasus
Posted 20 August 2012 - 09:09 AM
6- 8 weeks once I have them. The target is to provide everyone on the list with one before it gets cold.
#20 fezzasus
Posted 22 August 2012 - 01:20 PM
FYI. Dealing with the customs documentation for the blowers. Should be completing orders soon.
