Swapping Driveshaft
#21
Posted 09 August 2012 - 05:04 PM
#22
Posted 09 August 2012 - 05:55 PM
I used the shaft from an Astra H (aka MK5) 1.7 cdti (don't know partnumber) which also has the F23 gearbox.
You do need the locknut fom that shaft though, as it's different (32mm instead of 30 i think)
It may fit, but the 32mm nut sounds like it may have different CV joints.
Do you know or did you measure the CV joints/housings themselves to see if they have the same outer dimension as the VX ones or smaller?
If the CV diameter is indeed smaller then higher power cars (eg. SC or Turbo) may develop problems with these as they have less area to handle the power and the heat development.
This effect is commonly seen on Elises where the S1's originally have smaller diameter (rover) CV joints than the (vauxhall) S2 and unless swapped for larger ones they tend to run into issues with Honda conversions and such overheating the CV's. Nowadays almost all engine conversions on S1's use different/uprated CV joints for that reason.
#23
Posted 09 August 2012 - 08:26 PM
#24
Posted 10 August 2012 - 08:31 AM
On S1 conversions the drive shafts/joints are always swapped for bespoke items (which are expensive), its not a case of an option of swapping them. The overheating problem occurs on the bespoke driveshafts as the angle of driveshaft is such that the boot splits, the grease is flung out, the driver is unaware, continues to drive and the joint overheats, however I dont think I've ever heard of a CVJ/premature boot failure on a car that isnt used on track. For road use the shaft/CVJ seems to be more than up to the job.
#25
Posted 10 August 2012 - 08:32 AM
#26
Posted 15 August 2012 - 01:50 PM
#27
Posted 15 August 2012 - 02:03 PM
#28
Posted 15 August 2012 - 02:29 PM
#29
Posted 15 August 2012 - 02:34 PM
#30
Posted 15 August 2012 - 02:47 PM
I have had no driveshaft problems running at OE ride height (strange that ). Fit the Nitrons, ride height goes down, driveshafts at an angle, bye bye booty...
Just set your Nitrons to a sensible ride height. Mine have been on over two years and no split boots anywhere.
#31
Posted 15 August 2012 - 03:23 PM
Edited by smiley, 15 August 2012 - 03:28 PM.
