Wider Tyres 245F 215R
66 replies to this topic
#1 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 08 August 2012 - 04:39 PM
Im looking at getting some tyres but not sure what to get(ive currently got A048s, so loads of grip). I want as much tyre for my money and to go as wide as i can with no rubbing anywhere and i dont mind cutting the front arches out to accommodate for the 215 size. I was thinking 245/40/17 rear and 215/45/17 front. The tyres ive been looking at are YOKOHAMA AD08 = £570 (its looking like these ones so far as they have more tread new than the v70a) KUMHO V70A =£640 (whats putting me off these is lee has these fitted to his vx and they have rubbed slightly on the rear) FALKEN FK452 = £350 ( Seem to have gotten quite good reviews and you cant go wrong at that price but i reckon they wont have as much grip as the ad08/ v70 AVON ZZ3 = £348 ( Another quite cheap set of tyres with good reviews) If anyone has any more suggestions or any other vx lads on 245/ 215 tyre then sing away and let me know what you've got or any reviews on the tyres i've listed too
#2 G-Bob
G-Bob
    Embarrassing VX's in an MX5
  • 8,256 posts
Posted 08 August 2012 - 04:45 PM
You need some NanKang NS2's. They look really sporty see:
They come in 245/40/r17 for the rear (bargain £56.50) and 215/45/r17 (even more bargain £44.95) for the 17" wideboy setup.
They are very competitively priced and got a mighty 67% on tyre review site:
http://www.tyrerevie...Nankang/NS2.htm
Hope this helps. thumbsup
Edited by G-Bob, 08 August 2012 - 04:45 PM.
#3 derby-vx220
derby-vx220
  • 310 posts
Posted 08 August 2012 - 04:56 PM
I'm running on federal RSR tyres, 215 fronts and 225 rears. Not done many miles yet but definitely more grip than the standard re040s Demon tweeks were cheapest at 400 delivered. Alex
#4 Hark
Hark
  • 3,443 posts
Posted 08 August 2012 - 05:01 PM
Ad08 and V70a are comparable I would imagine although don't know about wear characteristics. Avon ZZ3 were on my wife's Rover 25 and I didn't like them on there. Ran Falken 452 on the TT for a bit. A good mid range tyre, but nothing like AD08s or similar. Can you get Toyo R1Rs in those sizes?
#5 techieboy
Posted 08 August 2012 - 05:04 PM
I don't think AD08 is comparable to a V70A. A048 and R888 are much more comparable.
#6 redvts
redvts
  • 1,472 posts
Posted 08 August 2012 - 05:06 PM
Federal rsr for me next, been in a few cars with them on, I was impressed, they arent that expensive and have 7mm tread from new. I think
#7 GeorgeBC
GeorgeBC
    Needs a cheaper hobby
  • 3,138 posts
Posted 08 August 2012 - 05:09 PM
My 245 v70 tyres rub and the a048 rubbed on cliffies race car, he runs very low with lots of negative camber
#8 Nev
Posted 08 August 2012 - 05:16 PM
Hi Haggi,
Which part rubbed? If it was the bodywork/clam, then you can shift the clam abou a bit usually and/or grind a bit of it away on the inside. If its the chassis (ie the inside edges), then you can buy hub spacers that can push the wheel outwards, these are relatively cheap and can be machined down to any thinkness for precission fitting.
2 points of advice would be (particularily as you have a powerful VX) to:
i) buy the best rubber and not think about price. Everything goes through the tyres :- braking, accelerating and cornering.
ii) Buy a road tyre for the road if thats your main use, only go to R888s or A048s when you wil principly be using the car on the track, otherwise you will struggle to get them up to temps on the road and they will vary in grip a lot more depending on hot/mild/cold days.
Edited by Nev, 08 August 2012 - 05:18 PM.
#9 GeorgeBC
GeorgeBC
  • 3,138 posts
Posted 08 August 2012 - 05:21 PM
You may find they catch the clam and the tub, mine do. Sizeten runs loads of power and runs 235
#10 techieboy
Posted 08 August 2012 - 05:28 PM
If I ever bother moving from the regular Exige sizes, I'll only bother going +1 size - 205 on the front and 235 on the rear.
#11 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 08 August 2012 - 05:29 PM
Hi Haggi,
It was the inside on the chassis/ tub that i could see the tyres had rubbed slightly on hard cornering. Would it not catch on the clam if i got a couple mm spacer fitted.
I am aiming to do a couple of track days a year and the rest is fast road driving, so i was aiming more towards the AD08S for that reason. What would you recommend?
Edited by haggi961, 08 August 2012 - 05:31 PM.
#12 MrSimba
MrSimba
  • 5,197 posts
Posted 08 August 2012 - 05:30 PM
BFOD thumbsup
A V70A is a true 'semi slick' racing tyre, the AD08 is a 'fast' road tyre & totally different!
#13 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 08 August 2012 - 05:34 PM
So i take it no one has found the perfect tyre that fits with-out no issues. When the tyres rub does it not knock the car out of its line?
#14 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 08 August 2012 - 05:36 PM
You know my thoughts Luke.... :) You can rule out RSR's if you want 235 rears though, they don't do that size.
#15 GeorgeBC
GeorgeBC
  • 3,138 posts
Posted 08 August 2012 - 05:48 PM
Just makes a horrible noise on the clam and will probably end up cracking it. Ended up with a 2mm spacer on the drivers side and no spacer on the pax side. I don't notice the rubbing on the tub but i get loads of rubber build up. I thought id go to 235 when i changed my tyres but ive changed them now and ordered 245 again and probably always will. V70 tyres have a big shoulder on them so maybe the federal rsr wouldn't be as bad as they really slope off on the shoulders. Cliffie new when his tyres were rubbing badly at cadwell. Another problem you will have is because you run the gaz golds you will probably catch on the dampener adjustment knob. Ran with a reasonable ride height, no spacers and a set of nitron 40mm shocks at le mans at the weekend and it only catched the tub, not the shock or the clam. When it was lower it caught the clam. Running -2.5mm camber.
#16 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 08 August 2012 - 06:15 PM
So many options to go for but my sensible head is telling me 235R and 205F.
#17 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 08 August 2012 - 06:19 PM
thumbsup
#18 Hark
Hark
  • 3,443 posts
Posted 08 August 2012 - 06:28 PM
BFOD thumbsup
They are PROPER semi slick aren't they. Hadn't seen any in the flesh. Apologises for my comparison then, it does make the difference between these and the Avons even bigger. :mellow:
I think as Nev said you need to think what the tyre is going to be mainly used for.
#19 Hark
Hark
  • 3,443 posts
Posted 08 August 2012 - 06:31 PM
Just gone up on seloc:
http://classifieds.s...trackday-tyres/
#20 techieboy
Posted 08 August 2012 - 06:33 PM
Bargain. thumbsup
