Removing Speedo Dials Etc
speedometerspeedo dials remove modification led upgrade supercalifragilisticexpialido
21 replies to this topic
#1 ChubbyChiper
ChubbyChiper
  • 69 posts
Posted 13 August 2012 - 05:01 PM
I'm looking at a LED mod/upgrade for the VXT speedo/rev dials. I have seen all the posts regarding this mod but seem to be stuck on getting the 1st circuit board out as it appears to be attached to the speed dial and rev dial and I can't work out how to separate them. I have the glass off etc. I've started to get me very mad and swear a lot at it, including a few personal insults but still nothing. We all know what the next course of action is is but inevitably that always turns out to be very expensive! Please help Imnotworthy :grouphug:
#2 CocoPops
CocoPops
  • 17,181 posts
Posted 13 August 2012 - 05:13 PM
Ianrm should be along shortly... he did his 2 weeks ago iirc
#3 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 14 August 2012 - 08:15 AM
Have you removed the needles?
#4 ianrm
ianrm
  • 11,097 posts
Posted 14 August 2012 - 10:37 AM
:yeahthat:
#5 ChubbyChiper
ChubbyChiper
  • 69 posts
Posted 14 August 2012 - 10:47 AM
No I haven't as no idea how they come off and didn't want to break them
#6 Darcini
Darcini
  • 2,508 posts
Posted 14 August 2012 - 11:11 AM
They simply pull off, it's a sphincter twitching moment but they will come off intact if you're carefull
#7 ianrm
ianrm
  • 11,097 posts
Posted 14 August 2012 - 02:03 PM
It was indeed a squeaky bum moment. Pull as straight as possible and with even pressure on both sides of the little black circle.
#8 ChubbyChiper
ChubbyChiper
  • 69 posts
Posted 14 August 2012 - 06:17 PM
YES!! Thanks guys, a little parp was heard when the needle got launched across the room but everything is intact so its all system go! Chuffed :happy:
#9 ChubbyChiper
ChubbyChiper
  • 69 posts
Posted 24 August 2012 - 05:54 PM
Urrmm, LED's changed (easy) thumbsup Dials not working now!!! thumbsdown Gulp! :tumble: SOS :excl:
#10 ianrm
ianrm
  • 11,097 posts
Posted 24 August 2012 - 07:25 PM
Is it both dials that are not working ? My Rev counter needle came off and left the metal spindle in place when I pushed it back on it worked fine. However the speedo needle came off with the metal spindle. When I pushed it back on it didn't work. It was trial and error but I gradually pulled it out a fraction at a time until it started working. I then went to put the clear plastic back in place and found the the needle was rubbing on that. I then worked out that if I shortened the spindle I could push it on enough to clear the lens and not enough to stop working again. So in a do or die moment I shortened the spindle enough. Hope that all made sense ?
#11 ChubbyChiper
ChubbyChiper
  • 69 posts
Posted 24 August 2012 - 11:22 PM
Yes it's both dials that don't work and yes that makes sense. Thanks for the tip. I shall give that a go tomorrow and see if it works. The spindle has a flattened part that i guess locks into the mechanism that turns the rev/speed dials so maybe its in too far or not enough
#12 ChubbyChiper
ChubbyChiper
  • 69 posts
Posted 25 August 2012 - 10:24 PM
No work :unsure:
#13 Hopegreen
Hopegreen
  • 94 posts
Posted 14 October 2014 - 08:41 PM
Hello,
I have the same problem. Since I bought the car two years ago the speedo needle doesn't work.
Now I was wanting to hide the ABS light and I've got to disassemble the stack.
I thought that it was a good moment to update the look of the stack.
After that I assemble it again but no needle works. It looks like all is fine but needles don't move.
Here a video of the fail moment.
Does anyone know something about this?
I tried to reset the stack doing this but it doesn't do anything.
[color=#0000ff;][font="helvetica, arial, sans-serif;"]Turn off the ignition[/color][/font]
[color=#0000ff;][font="helvetica, arial, sans-serif;"]- Open the driver's door (yes, really!)[/color][/font]
[color=#0000ff;][font="helvetica, arial, sans-serif;"]- Press and hold the trip-meter reset button[/color][/font]
[color=#0000ff;][font="helvetica, arial, sans-serif;"]- Whilst still holding the reset button turn the key in the ignition to the second position (just before the engine turns)[/color][/font]
[color=#0000ff;][font="helvetica, arial, sans-serif;"]- The Stack will then wind both needles back to below the zero position, and the LCD will show the software revision number. [/color][/font]
[color=#0000ff;][font="helvetica, arial, sans-serif;"]- Once it's gone through the motions your speedo should then read true![/color][/font]
I need some help... Thank you.
Edited by Hopegreen, 14 October 2014 - 08:43 PM.
#14 Goosenka
Goosenka
    Jeep Driving jolly nice chap
  • 12,716 posts
Posted 14 October 2014 - 08:49 PM
Sensor on wheel?
#15 Hopegreen
Hopegreen
  • 94 posts
Posted 14 October 2014 - 08:57 PM
Revs needle doesn't work now...
Before I took apart the needles, revs needle worked.
Edited by Hopegreen, 14 October 2014 - 08:57 PM.
#16 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 14 October 2014 - 09:06 PM
One of the abs sensors provides the speed feed to the speedo. So your problems are related. Although your rev counter one is separate.
#17 Zoobeef
Zoobeef
  • 11,103 posts
Posted 14 October 2014 - 09:07 PM
Left rear abs sensor. Usually a broken wire.
#18 Hopegreen
Hopegreen
  • 94 posts
Posted 14 October 2014 - 09:10 PM
I have a Scangauge II and it shows speed correctly.
I think I should reset the stack to recalibrate needles but I don't know how to do it.
Thank you for the help.
#19 Zoobeef
Zoobeef
  • 11,103 posts
Posted 14 October 2014 - 09:20 PM
As far as I know scanguage can't talk to the abs ecu? It's worth seeing what the abs fault is as maybe the scan gauge is getting a speed reading from somewhere else?
#20 Hopegreen
Hopegreen
  • 94 posts
Posted 14 October 2014 - 09:24 PM
The ABS fault don't worry me. I'm worried about needles.
I need the rpms needle at least because scangauge refresh is quite slow.
Also tagged with one or more of these keywords: speedometerspeedo, dials, remove, modification, led, upgrade, supercalifragilisticexpialido
