I found the problem. My stepper motor's axle seems to be quite sticky due to the disassembly. When you disassemble the needles it's better to do not get out the motor's axle if you want to avoid future problems. I tried to fix them but they only worked for a short time. I've seen that our stepper motors are Switec X15.166. They aren't available but you can use some direct alternatives like XC5.166. X25.168 is easily found and I read that it's quiet simple to adapt them (you should only cut a small parts of the plastic housing). I bought a couple of them in ebay and we will see.
Removing Speedo Dials Etc
Started by
ChubbyChiper
, Aug 13 2012 05:01 PM
speedometerspeedo dials remove modification led upgrade supercalifragilisticexpialido
21 replies to this topic
Also tagged with one or more of these keywords: speedometerspeedo, dials, remove, modification, led, upgrade, supercalifragilisticexpialido
Welcome to VX220.org.uk →
Guides and Tutorials →
Guide To Remove Fuel Vapour System.Started by Nev , 12 Jul 2019 ![]() |
General Discussion →
VX220 Discussion →
N/a Fuel LinesStarted by ee601 , 10 Apr 2017 ![]() |
VX220 Discussion →
K31 - Flasher UnitStarted by Vladimir , 28 Jul 2016 ![]() |
The Market Place →
Car Parts For Sale →
Downpipe For VxtStarted by turboluca , 25 Oct 2015 ![]() |
VX220 Discussion →
10.9 Tensile Grade Hub Carrier Bolts - Back In StockStarted by JG , 29 Jan 2014 ![]() |
