2005 Black Sapphire Vxt
#41
Posted 02 December 2012 - 08:35 PM
http://www.vx220.org...yout-schematic/
I think the stall issue could be down to a vacuum issue. I have now clamped the loose pipe but it doesn't seem to have made any difference. My next step is to look at replacing the rear boost control valve. I have already fitted one of the eBay Forge replica valves, with no apparent change.
Anyhow, finally took the car out today, first time since early November, hadn't expected to see slush on the roads! My excuse was to see if the turbo stall was still there, and also to warm up the gearbox fluid in advance of a change.
So, on the one hand, yes the turbo stall does still seem to happen, but on the plus side I do love driving this car!
Got it back in the garage, changed the gearbox oil and put it away to make space to do the diff oil on the CR-V. I really do need to use this car more often!
Anyhow, some pics;
#42
Posted 02 December 2012 - 10:12 PM
#43
Posted 02 December 2012 - 10:17 PM
sorry I shouldn't laugh as I'm a tubby owner too but couldn't resistI know the Tubby is heavy, but not heavy enough to use a bus only lane.
#44
Posted 02 December 2012 - 10:27 PM
#45
Posted 03 December 2012 - 09:40 AM
#46
Posted 03 December 2012 - 03:01 PM
#47
Posted 27 December 2012 - 07:27 PM
but would expect that from your other projects ive followed!
wouldnt mind a ride in yours to compare what mine rides like and the noises it makes, also Chris Foulds was the service good? wouldnt mind mine having a check over to make sure its all ok
#48
Posted 27 December 2012 - 08:28 PM
#49
Posted 27 December 2012 - 08:31 PM
#50
Posted 29 December 2012 - 09:43 PM
#51
Posted 29 December 2012 - 09:47 PM
#52
Posted 29 December 2012 - 09:52 PM
#53
Posted 29 December 2012 - 10:12 PM
#54
Posted 29 December 2012 - 10:18 PM
#55
Posted 29 December 2012 - 10:25 PM
#56
Posted 29 December 2012 - 10:40 PM
#57
Posted 29 December 2012 - 10:54 PM
Pleased it looks ok; don't be dissing the mighty 6000; my Focus only has a 5000 (just like 6000, but with a tape deck!), only use it for the radio and the aux function though. Good for deterring would be thieves!
Well my 6000 would in use decided it prefered urdu for several seconds at a time and was driving me up the wall.
#58
Posted 30 December 2012 - 09:13 AM
I think you did the right thing with that connection. I used the ciggi charger one for 6 months without issue but then it all of a sudden started popping out slightly causing bad connection and CTEK lights flashing. The direct battery connection has been faultless. Nicely routes out of the top of the bonnet. Only faff is having to pop the bonnet to fit, so looking at hiding it somewhere else maybe.I know, I did consider getting that one, but decided against it. Don't really have a good reason, I guess I preferred a direct connection to the battery.
Went for this one instead; http://www.amazon.co...ils_o02_s00_i00
#59
Posted 30 December 2012 - 10:23 AM
It has a cover for when it is not being used, does it not?
If so you should be able to feed it out the side of the wheel arch (between the clam and arch liner) so you have easy access to it, and means that should the battery die you can still operate the central locking to gain access to the bonnet latch.
#60
Posted 30 December 2012 - 10:37 AM
Yes it does have a little cover. Considered the wheelarch liner but it can get very wet in there (dispite the fact it's garaged and not driven in the rain ) I am sure I will find somewhere that sits well with my OCD
