2005 Black Sapphire Vxt
#61
Posted 30 December 2012 - 12:23 PM
#62
Posted 12 January 2013 - 08:55 PM
#63
Posted 13 January 2013 - 11:32 AM
While I was poking around in the N/S/R arch I noticed that the grommet for the headlamp wiring wasn't properly engaged; disappointing if it was like that from the factory. Didn't take much sorting out either, which probably makes things worse!
#64
Posted 13 January 2013 - 10:34 PM
#65
Posted 21 January 2013 - 09:32 PM
http://www.ebay.co.u...984.m1497.l2649
Cut it to the right length and refitted to both liners
Got the O/S liner in place this evening, need to complete the fixings next.
#66
Posted 22 January 2013 - 09:12 PM
#67
Posted 22 January 2013 - 09:43 PM
#68
Posted 22 January 2013 - 09:51 PM
Cheers, mine hasn't been out for quite a while, looking forward to taking it for a blast when the snow has gone and I have it put back together.
Yes you do.
#69
Posted 22 January 2013 - 10:18 PM
Edited by RalphyBMW, 22 January 2013 - 10:19 PM.
#70
Posted 23 January 2013 - 10:49 AM
#71
Posted 23 January 2013 - 10:50 AM
You feeling brave enough for a ride yet?
Just let me know when your out and about
I'll pm you my number
Alastair - would be keen to meet up once this weather is done, and mine is back together.
Edited by RalphyBMW, 23 January 2013 - 11:18 AM.
#72
Posted 23 January 2013 - 12:35 PM
I suspect that is aimed in my direction... The truth of the answer - No. The cravings are worse than when I was giving up smoking. Though, of all the things, the Puma has given me a bit of fun back to my commutes (bit like a nicorette patch).
I do however need to get out at somepoint with you and sample the black beauty.
#73
Posted 23 January 2013 - 01:01 PM
#74
Posted 27 January 2013 - 07:41 PM
Received a pair of new rear RE040's on Friday, collected freshly powder coated wheels on Saturday morning, got the new rears fitted along with the fronts that came with the car, did have some wear on the inside edges but plenty of life left in them and much better than those currently on the car which came with some used wheels.
Decided to go for anthracite wheels, just for a change, and I think they look rather good. What is less fun is trying to put new adhesive on the back of the Griffins. A friend with a bodyshop let my look through his collection of paint chips, there are thousands! I limited myself to GM colours and the wheels look very similar to Dark Tarnished Silver, same generous chap said that if I drop the centres off with him, he will paint them for me. In the meantime the new wheels are fitted with the silver centres, which isn't quite the look I was going for!
Before swapping over the wheels I refitted the n/s/r liner, what was awkward, one of the rivnut things was slipping, so it had to come out again, etc. also did the o/s/f HCB's, just waiting for an extra bolt to do the o/s/r.
I think the only other thing was to add another 350ml of gearbox oil.
Just need to check / adjust the tyres pressures and everything will be dandy.
And some fairly rubbish pics;
Excuse the quality of the pics, and the dirty car. Lovely job and quick turn around on the wheels by LSN Coatings in Castleford; £130 for the four.
#75
Posted 27 January 2013 - 08:56 PM
#76
Posted 27 January 2013 - 09:04 PM
#77
Posted 27 January 2013 - 09:18 PM
#78
Posted 27 January 2013 - 09:41 PM
#79
Posted 27 January 2013 - 09:46 PM
Cheers!
Not sure about the filler cap, but you are right, it will need to be done! Not sure how the silver face detaches from the cover?
With a very fine Phillips screwdriver & a little care!
Then it's an easy job to colour match both the surround & fuel cap
#80
Posted 27 January 2013 - 09:59 PM
